Question about NEC MobilePro 900 Handheld
BUSEFUL Backup
Why isn't the bUSEFUL Backup (Backup_NEC.Arm.Cab) on the Internal Disk?
    Master:
  • 903 Answers
The bUSEFUL Backup Plus Folder located in the Internal Disk of the Mobile Pro 900 contains a CAB file named Backup_NEC.Arm.Cab. This file is not marked read only and being a Windows CE application , it will delete itself after installing the application. To obtain another copy of the Bsquare Installation file, please locate this file on the included CD-Rom and replace the one in the Internal Disk as necessary.
Posted on Sep 14, 2005
What are buses when talking about network cards?
The paths taken by data moving with a computer are called "buses". Multiple side-by-side paths force data to move in parallel, and not in series (one after another).
Feb 14, 2013 | Computers & Internet
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
How do I make the floppy drive B?
  • Open the Disk Management console (diskmgmt.msc).
  • Right-click on any drive, and select Change drive letter and path.
  • Windows will let you know if the drive letter cannot be changed for some reason.
Mar 05, 2011 | NEC FD1231M 144MB 35" Internal Floppy Disk...
You need to format the disk in drive G before using it. Then when I click ok it says cannot be formatted.
the internal floppy drive is ALWAYS drive A: ...so be very careful you're not trying to format something (drive G:?) you shouldn't be. Perhaps your drive G: is a dvd or cd drive...or more likely a usb drive. Formatting the wrong drive is a bit catastrophic in terms of data loss.
Hope this helps.
Regards
nicam49
Dec 21, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
NOT APPEARING IN MY COMPUTER
If the Floppy Drive is not appearing in my Computer, open the PC and check that the cables are connected to the drive properly.
Also open Device Manager and check under Floppy Disk Drives that the drive actually appears there.
Aug 30, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
Where is the rear control arm on the 2001 pontiac bonneville and can a layman replace the busing in it?
I would say no. The rear control arm is bolted to the frame in the rear wheel area. It is rather involved to remove the control arm, and replacing the bushing involves using a press to press them out and install them.
May 02, 2010 | 2001 Pontiac Bonneville
I have a 96 F150 and I need to replace my clutch. My tranny code is M which should be the M5OD-R2 (correct?) I'm not sure if my clutch plate is a 10in or an 11 in.
You will take old parts in so no need to know ahead of time what size.
Basically clutch sandwiched between engine and transmission.
Transmission usually easiest to remove.
Drive shaft first.
If starter on tranny, then remove batter cable.
Sometimes ground strap.
Speedo cable, backup lights cable, etc.
Small bolts on bottom plate.
Support transmission and engine separately.
Some trucks have removable tunnel cover, which makes it much easier.
6 large bolts between engine and bellhouseing.
Lower transmission and back of engine only enough so you can slde transmission back.
Then slide it back out of engine and clutch.
Usually about 6 inches or less.
Then get it out of the way.
About 10 bolts on pressure plate.
Do diagonally and in steps.
Friction disk sandwiched between pressure plate and flywheel, will just fall out.
Throw out bearing is on fork back in bellhousing of tranny.
Check pilot busing in center of flywheel.
Supports tranny shaft, so must be good, well greased, no rust, no binding.
Install is reverse of procedure, except you need to hold the friction disk in center, while tightening pressure plate. They sell a cheap plastice stub shaft substitute that you can buy or improvise. But important, because you will be trying to get that heavy transmission with long imput shaft back through the fiction disk hub and into pilot busing. Alignment is critical. Sometimes turing engine helps.
Extra long bolts temporarity, also helps. A little rocking and shoving. Constantly compare gap on bottom and top of bellhousing to engine.
When it slides in, youwll know, and an bolt it back up. But don't try to just force it.
Also don't over tighern pressure plate bolts, because they are small. Use torque wrench.
Feb 18, 2010 | 1996 Ford F150 Regular Cab
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Sep 15, 2005 | NEC MobilePro 800
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800: ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
Sep 15, 2005 | NEC MobilePro 770
"Backup Battery Very Low"
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Sep 14, 2005 | NEC MobilePro 900 Handheld
NEC MobilePro 900 Handheld Logo
432 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
