SOURCE: No Sound
bring up the menu and activate the skeakers on/off feature ,also look in rear for internal/external switch .
SOURCE: Split screen question
Only if you have 1 Ant input, if you have ant 1 & 2 then you don't need a vcr for split screen.
SOURCE: how do i reset my
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
SOURCE: how do i hook up my big screen to my pioneer
Check your Service manuals for Each set, then you may need to buy some cables for the new hook ups..
the solution is on you hands as easy as one, two,three...
Good luck.....
SOURCE: I have a Bose Lifestyle V30 surround sound system
You need to use the IR emitter that came with the Bose V30 system. Bose employs a proprietary RF frequency remote which communicates to the hidden central control head. You plug in the emitter to the processor unit and run the emitters to the IR 'eye's' of the equipment you want to control. Once all this is done then and only then can you go through the remote codes to control a particular device. The Bose V30 has 2 IR emitters that come with the unit to control 2 devices. You can expand on that buy buying a IR emitter bridge that has several inputs for other devices.
Now when it comes to a DVR I am not so sure the Bose universal remote will work all the playback and FF and record control buttons and a DVD or VCR. I hear there is a new BOSE remote on the market that can do that but I have yet to see it in person or ask a sales rep about it. Sometimes they are non-tech's so its no help : (
