Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Wall oven error code
I bought my HBL745 over 3 years ago and it worked ok for the first 6 months, after which once a 1/2 weeks it would give an error code. Nowadays it gives it every hour (after I restart by switching off/on the braker).
The error code is:
SLV EE CHIP/
CKT BAD OR
RTDS NOT CAL
S-EE RESULTS
SUB5V-CHECK
SOFTWARE
I did call Bosch service while still in warranty and when they came the error code was not there (of course). I had called them several times after that and they never acknowledged it was an oven problem.
Could you please let me know how I can fix this?
Thank you
    New Friend:
Posted on Jan 03, 2016
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Posted on Nov 03, 2010
Tip
I have the same issue, however, whirlpool and the three recommended service...
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Dec 22, 2010 | Whirlpool RBS245PDS Electric Single Oven
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
F4 comes up every time I try to reheat a dish. I have had this oven for seven years and this started about three weeks ago.
hELLO THERE
Whenever you recieve he dreaded f4 or even a f3 error code this is telling you that the ovens temperature probe is not working properly it may be shorted out and in need of replacement.
If you would postme a comment with the make and model number of this oven i can get you the part and a price on this ok
Best regards Mike
Jan 13, 2011 | Ovens
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
1,720 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
