Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whilpool washer when the start cycle is on it dont spin at all;
    Novelist:
  • 166 Answers
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up."
Please rate me before you sign off1
Posted on Sep 08, 2008
How do I set spin only cycle
with alot of LG washers they dont a have a spin only cycle, i dont know why they dont but it confuses alot of people, if so you should see a button that allows you to change the spin speed what you do is when you turn it on DO NOT select a cycle just press that spin speed button then press start and it will do a spin only cycle :)
Oct 11, 2014 | LG Ultra Large Capacity White Front Load...
How do you fix a Whilpool Duet frontloader GHW9400PL0 that is loud during the spin cycle?
There are bearings on the drum that go out and sadly on the WP Duets, they aren\'t replaceable. You have to purchase an outer rear drum and replacing them is annoying. There are lots of youtube videos but unless you find a used one for parts, you will spend about $300 just on the drum and the labor for it will be ridiculous.
Aug 06, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Model LSE1000 - The washer is getting old and not spinning the clothes as dry as it used too. Am I looking at replacing belts, pumps or cleaning out something that may be causing this problem. The washer...
NEED TO KNOW NAME BRAIND IF WHILPOOL HOW OLD IF MAYTAG REPLACE BELT SAME WITH GE WITH WHILPOOL NEED MOR INFO TO HELP LIKE IS IT SPINING AT ALL OR SLOW IF SLOW MAY BE YOUR CLUTCH OR DRIVE BLOCK IF NOT AT ALL WILL IT AGITAT IF NOT DRIVE COUPLER IN BETREEN PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
Whilpool washer Model # LXR9445JQO During wash cycle the motor stopped working, became hot (you could smell it). Now the motor just hums and starts to get hot, you can't turn the agitator or basket by...
STOP trying to run the washer you will burn it up!!
You need to remove the agitater and make sure nothing is tangled around the shaft. If there isn't anything tangled you will need to do surgery on your washer. You will need to remove the back access panel and remove the lines from the water pump on the back "one going in and one coming out" pull the pump off the shaft and make sure that it spins freely. Hopefully the motor isn't burned up to bad from trying to run it!! have a GREAT day!
May 10, 2009 | Washing Machines
Control locked is on, how do i unlock it ?
I think you're on line. Okay, power shd be on, see that button 'end of cycle' on the right side of your panel? Hold it down for 3 seconds. You'll be ok. Dont forget to rate, its a way of saying thk u!
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whilpool washers drains but when done spinning puts water bk out
If you have a selection for extra rinces deselect it and try. If not almost certainly your timer is faulty.
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore washer fills and spins at the same time
If the washer has been recently moved the drain hose may be too far down the stand pipe causing a siphoning effect
Jun 11, 2008 | Tecnik TKL9260 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
