Question about KitchenAid 31 in. KGCS105 Gas Cooktop
Replace burner seals of gas cooktop
I've got a brand new 14 year old Kitchenaid glass gas cooktop which I just installed. The seals or gasket gave a horrid rubbery smell when the cooker is used for 10 minutes or more. I dismantled the burners and have been trying to replace the seals or gaskets. Kitchenaid/Whirlpool says my unit is obselete and no longer carry the seals. Any idea what other seals I can use to replace them? The original seals are like 1/16" in thickness and 3" and 5 3/8" D and 1/2" wide. They fit in between the ingniter unit and the glass top from underneath. One appliance parts company suggested canning seals but I fear they may not withstand the heat. Any alternatives and suggestions would be greatly appreciated, thanks!   product: Kitchenaid 30"gas sealed cooktop  model #ykgct305t
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
How to dismount KitchenAid cooktop model KECT 365
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Dec 30, 2013 | KitchenAid Cooktops
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
I have a GE glass ~ gas cooktop that is 14 years old. One of the burners has a hard time lighting and just flickers. If I turn on another burner at the same time it will light and I have to turn and push...
I would say that after 14 years your stove could use a checkup/cleaning by a professional who will readjust the settings afterwards so it operates as it should. Don't try it yourself it's dangerous stuff gas.
Aug 04, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Kitchenaid Gas Cooktop with electronic ignition
you sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
Nov 09, 2008 | KitchenAid Cooktops
Soapy water stains under sealed glass cooktop 4 rround burners about 6 years old
You should never use large amounts of water on any electrical appliance. If the moisture is under the glass, it will need to be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 08, 2017 | Cooktops
KitchenAid 31 in. KGCS105 Gas Cooktop Logo
308 people viewed this question
Top KitchenAid Cooktops Experts
vince
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
