Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60 inch philips projection tv 60PP9202 color fading/concave screen
I have had my 60" Philips projection tv (60PP9202) for almost 4 years now without any problems. Just recently I started noticing a drastic fading of the screen colors. Then yesterday when I turned it on, there was a black hump in the lower left hand corner that was making the entire screen concave. I've read feedback on this and see that I need a convergence integrated circuit. Can you tell me what the exact part name/number is that I need? Thanks!
  • 1694 Answers
SOURCE: Philips 60PP9202 60 in. Help
You will need a service call by a qualified technician....
Red & green = yellow, therefore the blue CRT has a problem..T.
Posted on Feb 21, 2008
Hauleywood
  • 9 Answers
SOURCE: no color adjustment
*CONVERGENCE SERVICE MODE PROCEDURES*
*Note: This procedure is required for all of the following geometry and
convergence adjustments.*
*Using the remote transmitter, enter the following seven-button sequence to
activate the convergence mode.*
* 06 - 25 - 97 - Menu (M)*
*The "Opening Menu" will appear offering choices:*
*Channel 3*
*Use Channel up/down to*
*Select a Channel with Video*
* Remote control key functions:*
* Use arrow up/down and left/right: Adjust Convergence*
* M: Advance "cross" location*
* Up, Down, Left, Right*
* 3: Exit Convergence*
* Status: Abort/Cancel Changes*
* M: Begin Convergence*
*Note: video information must be present to correctly adjust the
convergence. A signal source is required to lock the vertical and
horizontal sync. After entering the "convergence service mode" verify the
presence of a video source by confirming the presence of active audio (use
the volume up function on the remote). Use the channel up and down function
on the remote to select the desired tuning source.*
*Select item "M" from the first menu, the "Convergence Menu" will appear
featuring 5 possible selections.*
* Channel 3*
* Convergence:*
*1. green geometry*
*2. red To green Convergence*
*3. blue To green Convergence*
*4. green To red Convergence*
*5. green To blue Convergence*
*CONVERGENCE TOUCH UP PROCEDURE*
*1. Enter the "convergence service mode" as described above in the
"convergence service mode procedure".*
*2. Select the desired color requiring adjustment. Note: Do not
select Green Geometry (1). This procedure is described under "Major
Convergence/Geometry Alignment. If Green Geometry is altered during this
procedure a "Major Convergence/Geometry Alignment" maybe required. *
*3. Cover the Output Lens of the single color presently NOT being
adjusted. Example: If you select Green to Red Convergence (4) cover the Blue
Output Lens.*
*4. The highlighted adjustment Icon (Cross) should be illuminated on
the middle left side of the screen. Make the necessary Convergence
Adjustments using the following Remote Keys:*
*· Use the Arrow Up ( ) to adjust the selected color up.*
*· Use the Arrow Down Key ( ) to adjust the selected color down.*
*· Use the Arrow Right Key (-) to adjust the selected color to the
right.*
*· Use the Arrow Left Key (+) to adjust the selected color to the
left.*
*5. Move to the next location to be converged. It is not required
that the full Convergence Sequence be followed while performing the
"Convergence Touch Up Alignment Procedure". The following alternate Remote
Keys allow for positioning of the Icon to the desired adjustment location:*
*· Key 2 on the Remote Transmitter will position the Adjustment
Icon upward on the screen.*
*· Key 8 on the Remote Transmitter will position the Adjustment
Icon downward on the screen. *
*· Key 4 on the Remote Transmitter will move the Adjustment Icon
to the Left.*
*· Key 6 on the Remote Transmitter will move the Adjustment Icon
to the Right.*
*6. Return to the "Convergence Service Menu" by selecting Key number
3 on the remote transmitter or by sequencing the Icon to the last adjustment
point at the lower right corner of the screen and pushing the Menu (M) Key
on the Remote Transmitter..*
*7. Repeat steps 1 through 6 for other required Convergence
Alignments.*
*8. To Save the Adjustment completed in the last procedure,
Exit/Save the Convergence Service Mode by selecting Key 1 on the Remote
Transmitter. This forces the corrections to be written to the EEPROM on the
Convergence Module.*
*Note: To save the convergence corrections made above you must exit the
convergence menu by selecting Exit/Save Data (1)*
Posted on Jul 05, 2008
Ecollier2012
  • 3459 Answers
SOURCE: SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Posted on Nov 21, 2008
hardrocko
  • 1476 Answers
SOURCE: i have a phillips 60PP9202 60 the blue convergence
xlt1873,
Since you can move your beams but not far enough the convergence ICs are good. Your porblem is with the digital convergence box. You will need to replace it.
I have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which will help you complete the reapair.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Sep 27, 2010
Slinteriors
  • 8617 Answers
SOURCE: I recently bought a 60'
You will need the original remote to acces the convergence setting adjustments. You can get the original remote for your model from www.tvrepairworld.com
Posted on Jul 05, 2011
I have a Philips projection screen hd tv great picture but the color is way out off adjustment
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
SD TECH
Oct 30, 2011 | Philips 60PP9202 60" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Picture quality of colours fading
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
We have a philips projection tv 60PP920217F we can not alighn the blue color the picture is concaved on bottom and top
This is a convergence problem and can be repaired by replacing the two STK-392-120 convergence chips and adjusting the set with the original remote control
I have specific instructions for this repair from start to finish.
SD TECH
Feb 16, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Feb 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
