Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Dvd player Inserted CD with pictures of grandchildren into the DVD slot - it started to scroll pictures then stopped and now I can't eject the disk. I thought I could put any disk in - was I wrong and how can I get it out. Tried to turn it off and then hit the eject button on the TV also have tried the eject on the remote.
  • pscokato Sep 05, 2008
    Unplugged the TV for a minute - plugged it back in and it worked! This is a great service. Thanks!
    It worked - unplugged the TV for a minute - plugged it back in and it was back in working condition. What a service! Thanks!
  • 6,487 Answers
Try to tunr the dvd for about 5 minutes then turn it back on then try to eject the CD again and hopefully it will eject it now, if still not ejecting you may need to open the DVD then manually remove the CD stuck on it...
Hope that helps.....
Posted on Sep 03, 2008
    Genius:
  • 3,422 Answers
HI,
Please unplug all the cords of unit for 30min and then plug it back in.See if the disc ejects.
  • Priya darshan Sep 03, 2008
    Let me know the result..
  • Westinghouse Master
  • 13,433 Answers
Hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
I can not eject my cd from my dell laptop?
Open Start Menu, Computer, Right click on the DVD rom, scroll down , click on eject.
Dec 29, 2012 | Dell Inspiron 1764 Laptop
Tip
How to eject a disk from a slot drive, when you've tried everything else
This is about trying to eject a CD or DVD stuck in a slot drive.
Most computers have a drawer-based cd drive which rarely suffers from disk jams.
Some high end PCs (and nearly all Macs) have slot drives where you feed the disk into a slot, the disk is then pulled into the machine. This gives better structural strength to the case, looks neater etc etc...
The problem is that occasionally a disk will get stuck. and there’s no little release hole on the front to push a paperclip in. There is lots of advice on the internet for the Macs, the Wii, and Pioneer drives of varying types, and most of these advise OS tricks, or firmware commands, however this trick is for when all those methods have been tried, and the disk is still trapped in the machine.
The idea is to stop the disk spinning and fool the drive into thinking the CD is bad, and it will eject it. I was taught this trick by a retired engineer, and it works a treat.
Fold a piece of cardboard (I used the side of a Frosties box) lengthways twice, until it’s quite stiff... Carefully push it into the slot until it bumps up against the edge of the CD/DVD.
Start the machine, and push the cardboard firmly against the disk to prevent it spinning. Wait for the regurgitating noises, and remove the cardboard to allow the disk to be ejected.
Easy.
on Jul 26, 2010 | Computers & Internet
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Can't get a dvd to eject from from a Lexus cd player
basically just carefully insert another CD into the slot, but only about 1 to 2 inches of the disk and keep jiggling the disk around and pressing the eject button.
This was a suggestion for the lexus owners club wed site.
give it a try and if it doesnt work let me know and I will try to find something that does.
Jan 10, 2009 | Bose & Wave& Music System
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
385 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
