Question about Kenwood Audio Players & Recorders
Hi..A Kenwood KRX792 Stereo Cassette receiver..When power is turned on.. The main display lights up followed by the Cassette deck mechanism operating..Then the power shuts down within a few seconds..All fuses are ok....I tried disconnecting the speakers but that has no effect..Daniel..
SOURCE: Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Posted on Sep 04, 2008
  • 4234 Answers
SOURCE: Kenwood Receiver KR-a5020 receiver won't come out of standby
The unit is in what is commonly known as "protect" mode. This means that a problem has been detected in the final output stage of the amp and the outputs are shutdown to prevent further damage to either the receiver or speakers. This should not be a difficult repair for a service shop. Expect a parts cost in the $25-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Nov 28, 2008
SOURCE: Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Posted on Jan 04, 2009
SOURCE: Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Posted on Jun 03, 2009
SOURCE: Kenwood vrs-7100 surround sound receiver turns on and shuts off
The audio amplifier IC are fried
Posted on Aug 12, 2009
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
The word "protect" appears on my screen and shuts my unit off; what should I do.
Sounds like you have either a speaker wire exposed and/or crossed. Or speakers that are capable of too much wattage/ohms resistance for the receiver to match.
Jun 21, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
Kenwood cassette receiver rx-28
There are sensor leaf switches that may not be contacting properly or the drive belt may be too slack to position meachanism properly. Have it checked by pro/tech
Apr 13, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Mar 24, 2008 | Kenwood Audio Players & Recorders
288 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
