Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Wavey lines apex 5108 projection tv
Wheir to get a digal board
  • davesr7 Sep 03, 2008
    need help
  • Apex Digital Master
  • 19,396 Answers
The problem can be the convergence board, or a problem with one faulty component on the main pcb.
Here you can find replacements, if you do not find your model in list call them at 1-866-925-PART (7278)
Posted on Sep 03, 2008
HITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN SCREAN GOES BLACK
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 23, 2012 | Hitachi Televison & Video
Hi, I own a Apex gb 5108 TV, remote control is lost, can you tell me if any brand of "universal" controls will work on my TV? In my country there are not to many options...
universal controls dont work well with this tvs to change channels you have to go up or down you cant select a channel because of the button on the original control it has to be put in how many digits you want the best thing is to order a new one
May 08, 2011 | Apex Digital GB5108 51" Rear Projection...
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Wavey line at bottom of tv
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments any where,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it reistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Philips 60PP9363 60" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
Screens
IF YOU WANT A NEW SCREEN CALL DIRECT TO THE COMPANY 1-800-332-5368 IF YOU WANT A USED ONE, CALL TO THE TV SHOP AND ASK FOR A USED SCREEN IN GOOD CONDITIONS.
Dec 24, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence and wavey picture problem
Actually you have 3 problems. The two that you listed and the third which is: Apex does not support their units. Ask anyone who has tried to get any service. Your problem sounds like a bad digital convergence box. I fix this problem several times a week but on name brand sets. Cost is usually less than $100 for the part. Some problems with Apex equipment can be fixed if the part is a common off the shelf part. That is not the case with your problem. Apex equipment is cheap for a reason. All posts that I have read say that they do not last long and you can't get parts. That has also been my experience as a technician. We don't even accept Apex units for repair anymore. Next time spend the extra money to buy a name brand unit and it will more than likely be repairable.
Jun 01, 2006 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
67 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
