Question about MSI K8N Neo4-F Motherboard
No internet connection after drivers downloaded
I updated several drivers on my computer with MSI k8n-neo4 MB, XP and now no internet connection. Restore points not acessible. Onboard Wan not listed in device manager. I no longer have the driver disc. I tried installing a wireless card, but I get a message to use WZC. I tried to follow the instructions on the MS bulletin regarding WZC, but I get a message that the file does not exist ($SystemRoot%...). Is this a driver conflict or registry problem, or will I need to repair Windows XP?
Thanks
  • wlandlaufer Sep 03, 2008
    By means of your website, I was able to download the driver files on another computer.. I wrote these to a CD and reinstalled them on the MSI system. The internet works now and I don't see any problems in any other areas. Any need to repair windows?
    (ain't broke, don't fix it?)
    Also, I installed a WD120GB HD as a slave. I selected this drivein the my computer screen and tried to format it. Windows went through the process, then finally said it could not format the drive. Is the drive bad? Is it a reliable stroage drive?
    Regards
  • 6,487 Answers
Reboot the computer then press F5 or F2 so you access the boot menu , then press F8 for th advance option then select Boot from Last Known Good Configuration so you're computer will boot from the time when everything is working fine..
Hope that helps........
Posted on Sep 03, 2008
    President:
  • 1,263 Answers
When you installed the driver updates did it reconfigure your proxy settings for your network?
    Master:
  • 521 Answers
You will need to repair windows xp.
pls do rate the solution
thanks.
regards.
fixya expert team
Are there windows 7 drivers for a MSI K8N Neo4-F Motherboard
There is neither Windows Vista or Windows 7 Drivers for the MSI K8N Neo4-F. It is not compatable, http://us.msi.com/support/mb/K8N_Neo4F_PCB_1.0.html#support-test
May 17, 2014 | MSI K8N Neo4-F Motherboard
K8n neon 4 platinum 1 audio drivers
Hello you can download the drivers here:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=XP%2032
By selecting your windows system.
Click on the sound link for download.
The file needs to be unziped, before you install the driver.
Reboot after the install is done.
Here is no drivers for windows 7.
Here are the other models:
http://www.msi.com/service/search/?kw=K8N%20Neo4%20Platinum&type=product
Good luck
Feb 16, 2013 | MSI K8N Neo Platinum Motherboard
I have recently installed windows 7 but there is no audio sound i think drivers have not been installed that is why my computer is lack of audio sound to hear a music please make a hand to me i mean h
Hello here is the homepage:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=All
Here is no sound drivers for windows 7.
If i am wrong by the mainboard model, enter the ms xxxx number here:
http://www.msi.com/service/download/
The ms number is located on the mainboard.
The solution is to buy a sound card, to add on the mainboard.
You just have to make sure, the driver is available for your windows system.
A sound card, can be bought online, or in a computershop.
As i know, MSI is not planning to make drivers, for this mainboard for windows 7.
Good luck
Feb 01, 2013 | MSI K8N Neo4/SLI Motherboard
Audio driver download
Download here at msi:
http://www.msi.com/product/mb/K8N-Neo4-FI--PCB-1-0-.html#/?div=Driver&os=XP%2032
Select your windows system
Download the sound driver and unzip the file
before you install.
Good luck
Feb 25, 2012 | MSI K8N Neo4/SLI Motherboard
Need a users manual for ms-7125
http://www.msi.com/service/download/manual-4370.html
Select US, or chinese if you'd like.
If this answer helped, please rate it appropriately.
May 04, 2011 | MSI K8N Neo4-F Motherboard
I need install driver
You try the drivers for that K8N Neo4 here:
http://driverscollection.com/?H=K8N%20Neo4-FI&By=MSI%20(Microstar)
The model is slightly different but the components build onto the motherboard will be similar.
Mar 01, 2011 | MSI K8N Neo4 Platinum (MS7125010)...
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
I want complete motherboard driver
First verify that the board model is MSI K8N Neo4 Platinum/SLI. The following drivers may not work for any other board model.
There are two ways to download the drivers. First try the MSI live update utility. It will search for and automatically download the required drivers.
You can get the Live Utility from this page.
If somehow the utility does not work, go here and download the drivers manually one by one.
Please note that MSI does not provide all drivers for every OS and the board may not be compatible with newer systems.
Dec 04, 2010 | MSI K8N Neo4 Platinum/SLI Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
MSI K8N Neo4-F Motherboard Logo
53 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
