Question about Canon EOS-10D Digital Camera
Magenta cast For many months now I have been shooting products and artwork with a Canon 10D and 2 white lighting strobes with larg silver lined soft boxes.The problem I'm having is with a magenta color cast over the entire picture especially if I shoot red subject material.I have tried vast changes in parameters and white balance and nothing I do with camera settings seems to help, I must always resort to post processing in PHOTOSHOP CS. Could this be a 10D issue or ME?
    Sergeant:
  • 255 Answers
Mostly it is probably you. 1.) Use a Gretag-Macbeth Mini Color Checker in the first frame of your lighting set up (every time you change anything about your setup: move the lights ,change the softboxes, lower or raise the power settings. use the Mini-color checker or the Gretag-Macbeth DC Color Checker -- nott he regular Color Checker 2.) As suggested: shoot RAW, and learn how to use the Camera Raw function in PsCS to do a a decent white balance (use the patch next to, or the one two patches down, from the white square -not the white square for your white balance. Then use that setting for all of the images made with that set up.
Posted on Sep 14, 2005
    Sergeant:
  • 255 Answers
I guess it could be several things; perhaps the color temperature of your lights is the culprit. At any rate, it shouldn't be too difficult to correct - here are two suggestions: 1) Shoot in RAW mode so that you can fine-tune color balance after the fact and don't have to get it right in-camera. 2) Shoot a black/white/grey card in the same lighting as your subject. (all three "colors" on the same card) You can then use the eyedropper tool in either curves or levels to set the black and white points, and the grey eyedropper tool (when clicked on the grey in your shot) should get rid of any color cast, magenta or otherwise. Good luck!
Magenta cast on left side and green cast on right
We are OEM foundry adopting of advanced sol-wide (colloidal silica)investment casting process,produce castings of various kinds of carbon steel,alloy tool steel,wear-resistant alloy steel,heat-resistant alloy steel and all kinds of stainless steel &it's develped products,with an annual output of 600tons of investment castings production capacity,80% of them were exported to the United States,Germany,Janpan,Spain and other countries.
hot sale pneumatic fittings Pneumatic valve stainless steel casting...
May 26, 2016 | Canon LV-7265 Projector
Pink cast on whites canon 5d mark 2
This could be to do with the type of lights you are using and not the camera.
Apr 16, 2014 | Canon EOS 5D Mark II Digital Camera
Epson 7800 is printing a magenta cast
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the software install asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Epson Stylus Pro 7800 InkJet Printer
Canon Pixma 4500 when printing on photo paper there is a Magenta cast over the print, even on black and white prints
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Nov 12, 2008 | Canon Office Equipment & Supplies
Vivitar 6000CAF for Canon EOS doesn't seem to work on my Canon 30D EOS camera?
A more appropriate product is Suntax DRF14C for Canon 10D, 30D.
http://www.suntax.com.sg/DRF14.html
Apr 01, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Pink cast in non-auto modes
Have you tried tweaking the white balance?
Jan 23, 2008 | Canon PowerShot S3 IS Digital Camera
My 10d won't focus
At 700 images/week for 52 weeks, you're just about at the point where the shutter could fail pretty soon. I don't think that would affect AF though, and AF doesn't "wear out" with use (other than experiencing the random failures that all electronics do).
Sep 14, 2005 | Canon EOS-10D Digital Camera
White balance metering
Cameras need a white reference for that measurement, they don't get it from the meter. On your camera (which I think works pretty much like my 10D) you can take a picture of a white card (white reference); the camera would use that frame to set its WB in AUTO mode (AWB). You can also safely guesstimate the K value with a little practice for cases in which a white card is not available or no other white objects are at hand. White Balance measures the light K value which illuminates a scene it doesn't measure the objects in an image. Further, in some cases you may have mixed lighting which makes matters slightly more complex. For example: if you are shooting under tungsten ambient light and want to use flash as a main or fill light you'll have to use a gel on the flash to match the ambient light and set the camera to that K value. This will give uniform light cast (color). However, for creative purposes, it's desirable occasionally to let one of the two light sources "shift". In the example just given, if you set the camera to a K value of 5600-5800 (around a typical flash K value) and use the flash without gels then, the tungsten ambient light would appear as shifted (redish, the typical tungsten colorcast when used with daylight film/wb) while the flash light would be balanced and not shifted. This difference (shift) would give the picture a different feeling.
Sep 14, 2005 | Canon PowerShot EOS D60 Digital Camera
Manual white balance
Click the AF-WB button and then with the wheel in the back of the camera select either K or any of the other settings. If set to K then you must go to your Menu (click menu button on back) then go to Color temp. and select your Kelvin tempature. Hope that helps....
Color Problems
I know this contribution might be late, but try to avoid using the auto white balance. Use a tungsten mode and test each of its compensations until you get the desired result. I haven't had a similar problem on the 14n, but my D100 always places a magenta cast on white when shooting auto WB. I learned how to adapt the other WB modes to any situation.
Sep 13, 2005 | Kodak DCS 14n Digital Camera
Canon EOS-10D Digital Camera Logo
143 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
