Question about Polaroid PhotoMax Fun 320 Digital Camera
Fun! Digital 320: "Camera not connected." -- Serial connection
My PhotoMAX software gives a "Camera not connected" error message when I try to download images from my digital camera to my computer using a serial port connection.
    Master:
  • 450 Answers
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Posted on Sep 14, 2005
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 820 Digital...
ERROR MESSAGE: "Checksum error."
The Checksum error usually indicates a data transmission issue. This may be due to a loose connection, bad wiring, electrical interference (cross-talk), a physical problem with the device itself, or a conflict caused by another software program. * Make sure that the cable attaching the camera to the computer is secure at both ends. * Close down all of the computer's other applications before attempting to download. 1. Press the CTRL, ALT and DELETE keys simultaneously. This will bring up the Close Program Window. 2. Highlight the program that you want to close and select END TASK. The Close Program window closes only one program at a time, so you will have to repeat these steps for each program that you want to close. NOTE: The SYSTRAY and EXPLORER programs should be allowed to run. Do not select End Task for these programs. You will also want to leave any necessary programs running, such as those controlling a wireless mouse or keyboard.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
What is an ISSET_SE error?
When you attempt to install the PhotoMAX software from your CD-ROM drive, you may receive the following error message: "ISSET_SE caused a general protection fault in module (FILENAME) at (ADDRESS) where (FILENAME) is the name of the program file you are trying to run, and (ADDRESS) is the memory address at which the error occurs." This is an error that can occur with Windows 95 and 98 under certain conditions -- it does not indicate an error with the PhotoMAX software. This (error message) can occur if any of the following conditions exists: * Norton AntiVirus version 4.04 is installed and Norton AutoProtect is enabled. * You use LiveUpdate for Norton AntiVirus to download an updated version of Norton AntiVirus. * Microsoft IntelliPoint software is installed on your computer, and the Point32 program is currently running. * Microsoft IntelliMouse or Microsoft IntelliMouse Trackball software is installed on your computer, and the Mswheel program is currently running.
"Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
What is included with the Fun! Digital 320 camera?
# Fun! Digital 320 Camera # Serial interface cable # 9-volt battery # PhotoMAX quick start guide # Polaroid PhotoMAX Image Maker Software CD-ROM
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Polaroid PhotoMax Fun 320 Digital Camera Logo
157 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
