Question about Polaroid PhotoMax PDC 3035 Digital Camera
Where does PhotoMAX store photos on my computer?
I've downloaded photos from my digital camera, but I can't find the files on my computer. Where does the PhotoMAX software store them?
    Master:
  • 450 Answers
Photos downloaded from a Polaroid digital camera are automatically stored within special PhotoMAX folders on your computer's C: drive. The exact location depends upon your camera model. Click Here to find where PhotoMAX stores photos on your computer. NOTE: PhotoMAX automatically saves photos in the JPEG compressed format and names them according to when they were downloaded to your computer.
Posted on Sep 14, 2005
SOURCE:
What are the modifications to download pics from polaroid 640 se camera using windowsxp
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 20, 2013 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Wont download photos
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 02, 2009 | Polaroid PhotoMax PDC 4055 Digital Camera
Downloading Images
Downloading images from a digital camera can be very easy if you keep these basic steps in mind. After loading the PhotoMax software on your computer: 1. Make sure that both the camera and computer are turned off. 2. Confirm that the camera has adequate power (using the AC adapter is recommended; otherwise, make sure that there are fresh batteries in the camera). 3. Plug the serial cable that came with your camera into the serial output of the camera. 4. Plug the wide end of the serial cable into the COM port (serial connection) of the computer. 5. Turn the camera on and start the computer. 6. Launch the PhotoMax software (double-click the icon) from the desktop. 7. Click on Get Photo. 8. Click on Album or Camera. 9. Select Twain device from the Acquire From box and click OK. 10. Select your camera from the Select Source box. 11. Click the Acquire icon: (Thumbnails will be displayed). 12. Select images you wish to save from the thumbnails and click on Get Photos. Your images will now be saved to the album you choose.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
How do I the delete images so I can re-use the memory card?
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Can I use the PDC 640CF camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will not be able to use the serial port to download your photos. Only USB port downloads are supported under Windows XP for the PDC 640CF camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Can I use the Fun! 620 digital camera with Windows XP?
Yes -- by installing updated camera drivers , you should be able use your Fun! 620 camera with a computer running Windows XP.
Sep 14, 2005 | Polaroid PhotoMax Fun 620 Digital Camera
Computer "hangs up" when displaying the Polaroid Album in PhotoMAX
This error or system hang-up is usually caused by: 1. the camera driver software attempting to read a corrupted photo; or 2. there are too many photo thumbnails stored in the PhotoMAX temporary storage area. In either case, the problem can be corrected by manually deleting the Fun! Digital 320 camera thumbnails from the Polaroid Album (using the Windows Explorer or My Computer icons). Follow these steps to delete the Fun! Digital 320 temporary files: Step 1 -- Locate the temporary photo files If you are familiar with Windows Explorer, simply browse directly to: C:\Program Files\Polaroid\PhotoMAX SE\Digital 320 If you are new to browsing the file system, follow these steps: 1. Double-click on the My Computer icon on the desktop. 2. Double-click on the C: drive. 3. Double-click on the Program Files folder. 4. Double-click on the Polaroid folder. 5. Double-click on the PhotoMAX SE folder. 6. Double-click on the Digital 320 folder. Step 2 -- Delete the temporary photo files Inside the Digital 320 folder, you will see many files, most of which will be bitmap image files. All of the bitmap files that start with dsc_ (example: dsc_005.bmp) must be deleted. To delete the files, you can either drag them into the Recycle Bin, or highlight each file by single-clicking on it and pressing the Delete key on the keyboard. To select multiple files at once, hold down the Shift key on the keyboard as you click on them, then press Delete. IMPORTANT: Do not delete the following files from the Digital 320 folder: * 320popup.rtf * DscDrv_Polaroid.dll * Polaroid Album.exe
Sep 14, 2005 | Polaroid PhotoMax PDC 3035 Digital Camera
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Polaroid PhotoMax PDC 3035 Digital Camera Logo
105 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
