Question about Zephyr Pyramid ZPY-E30S Kitchen Hood
Zephyr ep30 range hood
I need to know what the electrical wires are hooked to. There is the typical black and white wires. There is also a green and yellow wire. I need to know what this wire is for.
  • Anonymous Mar 23, 2014
    wiring the motor
  • 146 Answers
That green and yellow is your ground wire....wire nut that to your bare copper wire feeding the hood.
Posted on Oct 06, 2008
I am putting in a 50 amp breaker in my panel.it has 3 wiresblack white and green. Do the black and white go to the breaker and the green to the ground?stan
You should have a red &, black
Code white is common
Code green is ground
With the colors you are work with this is not for a 240 volt 50 amp service. For the amps & volts you are running. You need to run 8 gauge.
WARNING!!! WARNING!!!
Please be carefully hooking something up wrong could kill you or your family. If you run to small of a wire you could START A FIRE and burn the house down.
A white wire can be used if you mark it with red or black tape at each end and it is 8gauge wire Then yes if hooked up correctly it can go to breaker.
I don't know what you are hooking up but please be careful.
** TURN OFF ALL POWER WHEN WORKING IN A ELECTRICAL BOX. USE A METER TO SEE POWER IS OFF** STAY SAFE, THANK YOU
May 16, 2010 | Kitchen Ranges
How yo wire up ceiling fan with light
Typically with only one switch controlling the fan/light the connections in the ceiling are white to white, black to black and blue. if you have a separate switch for the light and one for the fan, typically the wiring is white to white, black to black, red to blue.
Mar 07, 2010 | Dacor Remote Light Control for Ventilation...
Well i attaching a four prong power cord to a washer and im looking for some help with the wiring configuration. (the red, green, white and black)
Hi, Red and Black are the hots. White is the neutral and green is the ground. Typically on a connector block the 2 hots red and black hook up to the 2 outside terminals and the neutral goes in the middle. The green hooks up to the chassis on the machine. There is normally a green nut to indicate where the green hooks up to. If you have any other questions please feel free to comment. Mike
Dec 24, 2009 | Kenmore Elite HE4 Electric Dryer
I need to install a kenmore range. the wires coming from the range are red, white, black, and green. The wires coming from wall are black, white and copper. How do I connect the wires?
Hello, Here's how to hook it up:
Black from wall to black at stove.
White from wall to red at stove.
Copper from wall to white and green at stove.
Hope this helps. --W/D--
Jul 31, 2009 | Kenmore Kitchen Ranges
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
I have a three wire lead out of my junction box (bare wire ground/white/black)and my new GE JTP 30 electric oven has a four wire (extra red). What is the wire configuration needed for reinstalling?
hook from the range the green and white wire to the bare copper wire from the house
hook the black wire from the range to the black wire from the house
hook the red wire from the range to the white wire from the house
Apr 24, 2008 | Kitchen Ranges
I have a brand new electric Jenn Air Convertible Cooktop ModeL C101-C , has two coil burners and a baraque grill. i need the electric diagram to wire it in to my electrical panel. which wires are...
black and red hook to the 240 volts white is nutral and green is frame ground if you do not have a green wire then bare copper to bare copper or green to bare copper national electrial code
Apr 11, 2008 | Kitchen Ranges
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Miele DA230-2
The latest DA230-3 hood is a 120V 15amp model and has a black/red wire to live, a white wire to neutral and a green to ground.
You may have a 220V model. I suggest to have a licensed electrician hard wire according to the voltage, load, and circuit rating listed on this data plate.
Dec 26, 2007 | Miele Designer DA230-2 Kitchen Hood
Zephyr Pyramid ZPY-E30S Kitchen Hood Logo
256 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
