Question about NEC MobilePro 880
Windows CE device
When using a Windows CE device, why I am unable to use the system after the error message: Not enough free space to delete 'filename'?
    Master:
  • 903 Answers
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Posted on Sep 14, 2005
5 Suggested Answers
SOURCE:
  • 903 Answers
SOURCE: Windows CE device
  • 903 Answers
  • 903 Answers
SOURCE: Error message: "Not enough free space to delete 'filename'"
Posted on Sep 15, 2005
  • 903 Answers
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows CE device
Sep 14, 2005 | NEC MobilePro 750
Windows CE device
Sep 14, 2005 | NEC MobilePro 250e
NEC MobilePro 880 Logo
179 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
