SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
SOURCE: danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
If you receive an answer to this I have the exact same problem... dougakers at msn dot com
SOURCE: My Danby DPAC8099 leaks water. Neither the
More than likely, either the tubing that drains water to the tanks(s) has become disconnected or it is clogged. I betting that it's clogged. to troubleshoot this, follow the instructions below.
Turn the unit OFF & Unplug it.
Remove
the water collection buckets and look up inside the bucket holder
cavity. You will see either a drain hole or small tubing that drains the
water into the bucket. Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reinstall the bucket, plug the unit in and turn the Master
ON/OFF Switch to ON. Allow the unit to run,
while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you can use something similar, like a long pipe cleaner. NO wire coat hangers though.
Hope this helps you solve the problem.
