Question about Dell Axim X5 Pocket PC
Backlight not working
I recieved my Axim X5 3 days ago. last night (Friday) my backlight stopped working. I tried to call technical support, but I was on hold for 2 hours. What is Dell's problem. First my Axim looses it's backlight after 3 days of use and then tech support is overrun by customers having problems with their Axims? I may just spring for the Toshiba e740 if I can't get this resolved quickly. I don't intend to wait another 1 1/2 to 2 weeks for a replacement or repair on this one. Has anyone else had the backlight problem?
    Master:
  • 852 Answers
I discovered today that if you push and hold the record button in it dims the screen down all the way and the settings brightness screen is dimly displayed with the 'on battery power, slider all the way to the left, you have to slide it back to the right to bring up the brightness.
Posted on Sep 14, 2005
    Master:
  • 852 Answers
Did you try to set the Backlight on in the control panel? (settings>system>brightness) The brightness is often automatically set to 0. If you did this already and it still doesn't work, probably try an email.
Honda accord 2005 clock stop working, since couple of days clock not visible during night and now stops completly
The display backlight for the clock is likely burned out, pull the clock and have it repaired.
May 12, 2016 | 2005 Honda Accord
How can I change the color of the red radio backlight?
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Radio Backlight Color Harley Davidson Forums
Apr 06, 2012 | Harley Davidson Motorcycles
My Sony VAIO Laptop screen is black. It worked fine, no issues2 days ago. Went to turn it on last night and it is black.. When light hits at a certain angle, I can see the desktop, I can hear the startup...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
http://www.youtube.com/watch?v=jjXLR5yY7X4
Sep 21, 2011 | Sony Computers & Internet
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Dell Axim x50v
I think you are looking at a new display if the backlight can't be replaced.
Sep 29, 2009 | Computers & Internet
How to turn the backlight back on
you should go to settings. display settings backlight and the select how many seconds you want it on for.
Jul 28, 2009 | T-Mobile Sidekick ID Cellular Phone
Sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Nov 08, 2008 | Sony Televison & Video
Ibm t20 no LCD backlight
while the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Apr 10, 2008 | IBM ThinkPad T20 2647 Notebook
Is it a problem with Axim -- automatical reset !
There are two different power conservation options that you want to look at. The first is in Settings -> Backlight and can control having the backlight turn off if the device isn't in use. The second is in Settings -> Power which has a setting to turn off the device after x minutes. That could be on, and that is what you are seeing. If the device is actually resetting itself (all running applications close), then you could have a bigger problem and you should contact Dell support.
Sep 13, 2005 | Dell Axim X5 Pocket PC
PDA screen?
Reflective LCDs do not have a backlight, because of this they can be difficult to use in some lighting situations. The Transflective LCD can be read while unlit, by ambient light, but it also has a backlight, which makes it better in low light situations.
Dell Axim X5 Pocket PC Logo
335 people viewed this question
Alun Cox
