Question about HP Compaq Presario V2000 Notebook
Compaq v12000 hi im not able to connect online i called and they said i have a virus on my computer i have tried restoring at an earlier point but still doesn't work
    Genius:
  • 1,239 Answers
Hi.. sir
which anti virus are u using.
u may have the anti virus software but it may not be updated.
please updated..with this following link sir www.softpedia.com/get/Others/Signatures-Updates/Kaspersky-AntiVirus-Update.
thank's sir
Posted on Sep 03, 2008
Ethernet connection died
This could be related to a lot of issues not enough ram causing memory dumps ,Virus or Malware , or Faulty ethernet lead.
Will it start without the ethernet lead connected ?
Does it start in safe mode ?
You might have a virus or malware or it could be a hardware issue
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
if this fails you might have to go back into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
other than that you might need to do a format and then re install your operating system
Jul 02, 2013 | Computers & Internet
System stops working until reboot
Step 1:
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials if this fails you might have to go back into safe mode you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. other than that you might need to do a format and then re install your operating system
Feb 23, 2013 | HP Compaq Presario CQ57-229WM Notebook PC
Why my Computer is not giving sound ?
Please check using a headphone and if there is sound the problem is with the speakers. If not open the AUDIO PROPERTIES settings and check and update the drivers. If not there are errors in the operating software( OS) and might need a reinstallation along with the drivers.
This can happen due to some virus from music downloading sites. try and restore the PC to an earlier restore point or use the recovery disc.
Thank You for using fixya.
Aug 09, 2011 | Compaq Presario 700 470024-192 Notebook
Hi i let myu boyfriend go online i asked him not to go on any game sites and download from them., i come home and turn on laptop and it is soooo slow., it takes at least half hour to work and when i open...
Click Start
Click All Programs
Click Accessories
Click System Tools
Click System Restore
Use System Restore to "restore my computer to an earlier point in time",
i.e., pick some date/time before your UNTRUSTWORTHY EX-boyfriend started to use your computer.
This "time-travel" should work. Then, do a "full" virus-scan, to see if any viruses are still present.
Apr 09, 2011 | Dell Latitude D410 Notebook
Cannot detect usb
Please try and restore your PC to an earlier date. Open the control panel , open back up/ restore and choose the program restore point.
If this wont solve reinstall the drivers or else there can be virus in your system that needs an OS installation with the drivers installed once again. have a good anti-virus installed immediately
Dec 31, 2010 | HP Compaq nx5000 Notebook
My computer phone will not work all of a sudden . I call out and it just calls out and cuts off at one ring . It says I have a 49.00 balance of un used on account . I even tried to add money and it refudes...
This sounds like a computer problem.
Restore your computer to a time when it worked correctly. To do this:
Windows XP:
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
Also, run a virus and spyware scan to make sure you have no viruses. This can cause software problems as well.
Hope this helps!
Oct 03, 2009 | Computers & Internet
Can you help me get reed of vires they are making my pc slow down
You can download a good free anti virus like Avast, Avira and also download this one anti malware software its called Malwarebytes, this will help you clean your computer and remove all infections...
Sep 18, 2009 | Computers & Internet
Virus Side Effects; Safe Boot; Drive Access denied
try to restore your system ;
start, all program, accessories, system tools, system restore and try to restore an earlier point which you will choose
Sep 14, 2009 | Microsoft Windows XP Professional With...
No Internet
You may try checking the network driver of your computer.
1. click start --- right click "My computer / Computer".
2. click Manager then look for device manager.
3. under device manager on the left column. Look for your network adapter if it has a yellow question mark or a red x mark.
Red X - disabled.(right click then select enable)
yellow mark - driver is not installed/corrutped (you need to install the driver online or from the cd that came with the computer)
4. Restart
Now, if the issue still the same. Try a different computer and check if you can connect to the internet. If the issue still the same. Call you Internet service provider to check on the connection.
Keep me posted.
Thanks.
Oct 26, 2008 | Dell Inspiron 1000 Notebook
My system restore does not function
make sure you are selecting a date that is
bold ,
some viruses will stop you using the restore function,run anti virus and anti spy ware
then try this:
go to start/run and type in cmd
then type in the black box sfc/scannow,
have your o/s disc ready as this will check all the system files and replace any that has got corrupted, from the o/s disc.
good luck
Terry
Mar 28, 2008 | Compaq Presario X1000 Notebook
HP Compaq Presario V2000 Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
