Question about Toshiba 27A44 27" TV
Do I need a converter for the February 2009 switch over?
I'm not sure if this set - manufactured in late 2004 - needs a converter?
Thanks,
Don
  • 4,234 Answers
If you receive you rsignals from a set of rabbit ears or an antenna, yes you will need a converter. If you have cable or satellite a converter is not neeed.
Dan
Posted on Sep 03, 2008
Two questions: My Insignia NS-LTDVD 19 flat
This model/brand of LCDs does need a digital converter since they are a low end quality product, the manufacturers did not put an ASTC tuner to decode the HD signals.
The DVD assembly can be replace to fix the DVD issues.
I have a couple of these DVDs assemblies from a broken screens LCDs and they're like new condition.
Let me know if you need further assistance.
Jun 23, 2010 | Insignia NS-LTDVD19-09 LCD TV
Telewest Codes for 26 February 2009
hi here are codes at 25/2/09
00= aa b7 d1 d9 ce 8e 83 af
01= a1 38 06 29 24 29 8d 2b
hope u get and running.
Feb 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
Not sure if converter box is needed???
Hello Ann, I will try to help you, well if your for sure about the Manufactur date on the T.V., then yes you will need a digital converter box, also it is suggested to have an outdoor UHF/VHF antenna with coax to attach to your converter box, the old rabbit ears aren't suggested. I hope this helps in getting you prepared for Feb. 19, 2009 when all T.V. stations broadcasting will convert to the new signal. Thank You and Have great day.
Jan 15, 2009 | Sharp 27L-S100 27" TV
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Does my Jensen TV TS2750J have a digital tuner?
    I called another aervice, they responded in 10 minutes, my TV does Not have a digital converter but it will work with any cable company after February 2009.
    Dec 11, 2008 | Jensen TS2750J TV
    Question about going digital in Feb 2009
    if you have Comcast you should be fine. The only TVs that need converter boxes are the old fashion ones with the bunny ear antennas.
    Nov 08, 2008 | Samsung TX-R2735 27" TV
    DTV in Feb. 2009
    I called the manufacturer and they gave me the info I needed.
    Aug 23, 2008 | GE 35GT695 TV
    Have a problem
    Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
    What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
    Antenna ---- converter box ---- Switch box
    XBOX ---------------------------------switch box
    DVD -----------------------------------switch box
    And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
    Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
    Is my tv digital compatible or not
    https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
    Here are some general guidelines that may help:
    TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
    If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
    Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
    2006 RCA TV Digetal Receiver
    NBC newsperson said I should check nbc.com to learn
    what to do for the change in February. Where is it ??
    You want my solution ? Improve your web site.
    Feb 23, 2008 | Televison & Video
    Toshiba 27A44 27" TV Logo
    56 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
