Question about Acer TravelMate 2300 Notebook
Acer security I have a laptop travelmate 2420 and use microsoft 2003. I e-mailed document files from microsoft word 2007 and I am unable to open them. The files appeared on my desk top with a red circle with a line through it overlaying the file. A pop up window with acer security asked for me to input passwords which i have done so and it is now coming up with error code 1302-2 can you advise?
  • Arthur Keech May 11, 2010
    Do you know if the files were password protected by Microsoft 2007 Professional Edition?
  • 40 Answers
Could it locked, or your password is incorrect
Can you copy to another PC see if you can open it
Posted on Sep 16, 2008
How do i remove the cover on my acer 2420 laptop to replace the cmos battery?Some one please help
You have to probably remove all the screws under the computer. remove the hdd memory and etc. The next part will be to check near the keyboard if there is something to pull out, underneath that there will be more screws to pull out and you will the cmos battery.
if your computer is the aaccer travelmate 2420 you can also check this website http://www.wiquestions.com/questions/les-instructions-de-demontage-pour-un-acer-travelmate-2420/
it's in french but just translated with google
Pascal
May 20, 2012 | Acer Travelmate Series 2410, 2420, 2440,...
My msword 2003 showing file convertor error in all files my data is v importent pls help me
ARE YOU TRYING TO OPEN WORD 2007 DOCUMENT IN WORD 2003. FOR YOUR INFORMATION, WORD 2003 CANT OPEN DOCUMENTS CREATED IN WORD 2007 FORMAT UNTIL THEY HAVE BEES SAVED IN WORD 2003 FORMAT( YOU GET THIS OPTION IN SAVE AS DIALOG BOX).
You may receive the following error:
Word cannot start the converter mswrd632.wpc
This error is cause because of f the security update for Windows XP, Windows 2000, and Windows Server 2003 on December 8, 2009.
You may experience mail merge issues write files are parsed but no message is shown.
To resolve this issue, an affected user can unregister the mswrd632 converter by editing the registry as follows:
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Text Converters\Import\MSWord6.wpc
On the Edit menu, click Delete.
Click Yes.
Exit Registry Editor.
NOTE: For x64 systems above path is slightly changed:
HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\ CurrentVersion\Applets\Wordpad
This change will effectively unregister the converter and disable it for third-party applications and for Microsoft Office. Microsoft Office will use its own text converters to open these kinds of files.
You can also fix this issue with applying the registry fix, but that is a less secure way according to Microsoft, as this fix actually creates 'AllowConversion' key in the new 'Wordpad' subfolder. (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Applets\Wordpad)
Download REG fix
There is another way to solve this issue by copying the MSWrd632.wpc file from another computer that doesn't have this issue. Make sure that this file comes from a trusted source on your network. This file can be found on the following path:
C:\Program Files\Common Files\Microsoft Shared\TextConv
OR DO THIS
Go to Tools > Options > General (Tab) in Word 2003
And check "Confirm Conversion at Open"
When you next try to open the document it will prompt you with a list to convert from. Choose Word 2007 and your document will open.
Have in mind that you will have to unregister mswrd632 first, which is noted above, before you make this changes.
NOTE: If none of this works, please check that your file is not corrupted, or that you or someone else didn't add X at the end of .doc extension or vise versa. This WILL NOT work! You have to convert the document using Office 2007 or 2010.
Dec 06, 2010 | Microsoft Computers & Internet
I am not able to open any attached file in the incoming mail showing error like documents is damaged. But I can open that in direct mail server please help
If you are unable to open any attached file in your incoming mail and are using Microsoft Office 2007, run registry editor (regedit.exe) and scroll to the following location:
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Security
Copy the contents of the "OutlookSecureTempFolder" key and paste it in the Windows Explorer to open the OutlookSecureTempFolder. Delete all files in this folder and then run Outlook.
This location can not be browsed to and can only be found from the registry as it is different for all users. e.g. for myself it is as follows:
D:\Users\keekus\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.Outlook\R34DKK8O\
For earlier versions of Microsoft Office, you may find the "OutlookSecureTempFolder" in these locations:
HKEY_CURRENT_USER\Software\Microsoft\Office\11.0\Outlook\Security
or
HKEY_CURRENT_USER\Software\Microsoft\Office\10\Outlook\Security
Jul 13, 2009 | Microsoft Office Outlook 2007: Windows
Reprogramming Acer Travelmate 2420
Hey,
read this page on how to reinstall or upgrade windows xp
http://support.microsoft.com/kb/316941
Thanks and good luck.
Ekse
Apr 26, 2009 | Acer TravelMate 270XV Notebook
Microphone connect have acer aspire travelmate
It appears that your Acer has 3 ports in the front center bottomportion of the laptop. One of them should be for plugging in an external microphone, one should be for external speakers, and one should be an input jack.http://complap.com/yahoo_site_admin/assets/images/acer-travelmate-2420-2.192120139_std.jpg
Feb 27, 2009 | Acer Aspire One PC Notebook
Keyboard locked out for microsoft word 2003
It's not the keyboard. If it was, it wouldn't work in anything.
It's possible that the "normal.dot" template is protected. This will result in any document created using that template also being protected. Try going into File -> New and creating something specific, for example a menu, that uses a different template. If suddenly you can use the keyboard, then you've found the problem.
Under those circumstances, use the Windows Search tool to find the file "normal.dot" and delete it. When you run Word again it will create a new, unprotected document template called "normal.dot" and Word should function correctly from then on.
May 23, 2008 | Acer TravelMate 354TE Notebook
Acer travelmate 2420 laptop
You don't need the original setup cd as long as you have the windows cd you can boot up the pc using that cd and just repair the windows or install it over cause its only a file messed up. Get back to me
Apr 17, 2008 | Acer TravelMate 2300 Notebook
Acer e-mail and encrytion problems
OTHER computers can only open Office documents if they also have the same version of office or a HIGHER (newer) version (backward compatibilitiy)
Office 2007 doc can open ONLY with Office 2007.
Both computers must have Office 2007.
But if you have Office 2007 you can open any OLDER Office doc (Office 2003, Office XP, etc.)
If much older, (Office 95 or earlyier) there is a conversion program to open the older version with a newer version.
"Did your problem get solved? I hope my suggestion helped. Let me know."
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
