Question about Bissell Vacuums
My bissell 3595-2 vacuum cleaner started turning off the power automatically. Now I can not get it to turn on. This vacuum cleaner is still in real good condition, as I have hardly used it. Please advise what could be wrong. I was thinking maybe a loose connection with the on-off switc.
    Master:
  • Bissell Master
  • 851 Answers
Hello, this is Ava with Think Crucial.
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: the thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Sep 03, 2017
reddevil6
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
  • 40 Answers
SOURCE: directions for Bissell upright rug shampoo vacuum
Indeed, losing directions can be quite frustrating. Below, I did some research and found a website which has most Bissell Vacuum cleaner manuals and directions online
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_product_list.html?s=gg314159
Hope this helps.
FerrariXP
Posted on Mar 17, 2008
reddevil6
  • 1673 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
I assume you mean the vacuum motor isn't running, could be the switch, cord or the motor, If you are able, I would start with the switch.
Posted on Jan 04, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
I have a bissel proheat and i can't figure out how to switch it from carpet cleaner to upholestery/stair cleaner. There's no button or switch that I can see and it doesn't kick in automatically.
On the most current model of the Pro heat 2X, there is a dial on the clear plastic section (located on top of the bladder section) and you can turn it from floor use to tool use.
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Is the brush on the bottom suppose to automatically spin when powered on?
If its upright the brush will not turn.It only turns when in pushing position.
Jul 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Screeching motor on a bissell 3595
Your motor is must likely bad and you would look at around $60 to $70 for a new one.
Nov 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
I have a Bissell 3760-2 and while vacuuming it just shut off. The vacuum was plugged in and was on. Thought it might have quit because of the filters, so I cleaned them out and still does not work. Please...
Most Bissell vacuums have Thermal Motor Protection which is a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting. When the motor cools for approximately 30 minutes, the thermal protector automatically resets and cleaning may continue. If the cleaner will not turn on or the thermal protector continues to activate, your cleaner may need servicing.note: The thermal protector controls the main vacuum motor only, not the brush motor. If the thermal protector activates, the brush will continue to operate normally; however, there will be no suction.
Ava B.
Apr 01, 2008 | Bissell Vacuums
Bissell 3595-2 Where is dirt going?
If the dirt isn't going into the dirt tank, then you have a clog either in the hose, or the dirt inlet by the brush roll. Clogged filters can cause suction problems also, they need to be cleaned often.
Mar 09, 2008 | Vacuums
Vacuums Logo
89 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
