Question about Compaq Armada M700 Notebook
Error messages I have a compaq Armada v300 and the problem is I put in a new hard drive. but when I went to boot the laptop I got an error msg. "1782-disk controller failure. then it left from the screen to another with the error " non-system disk or disk error replace and strike any key when ready. when I do I keep getting the same error msg. I have looked and there is no floppy or cd in the laptop and I continue to get the same msg. I have even changed the boot seq. and still get the same two error messages. What can I do to stop the error msg. so that I can boot the laptop. I want to reimage it. Hi i have a compaq armada m700 that gives a 1782 disk controller failure. I have tried 4 different HDD,s in it but still the same problem. I have disconected the bios battery still the same. it has very basic bios. The only way i can use it is with Linux live CD
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Posted on Sep 17, 2008
3 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Compaq Armada V300
Sounds as if the board is starting to fail. Try what I've listed bellow. If that doesn't work then try a bios flash. If it's still giving you the same problem after trying all of these, then I'm afraid you'll have to replace the motherboard.
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart, shut down, then put it back on again
or
Remove the CMOS battery from system board and boot once . After booting shutdown your system and insert the battery back, start your system and press F1 next time it won't ask you to press F1. Reset your BIOS after that (time,date,etc.)
Please let me know.
Posted on Jun 26, 2008
tom19511
  • 1601 Answers
SOURCE: error messages
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Posted on Dec 01, 2007
Error Message: F12=Network Service Boot
The BIOS may have reset to the default settings. Sounds like this was originally a workstation on a Corporate Domain Network. Access the BIOS and reset the boot order for CD first, then Hard Drive - you can even disable Network as a boot option. Power spike won't affect the Hard Drive contents, but it can reset a BIOS. Your win2000 should be intact.
Mar 11, 2010 | Compaq Armada M700 Notebook
I have a message that says , error message: PXE Media test failure chek cable
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
Sep 30, 2009 | Compaq Armada E500 Notebook
Error reading hard drive laptop Armada M700
It's sadly possible your hard drive is bad or corrupted. Can you boot from a CD? Or a floppy disk? You could run diagnostics on it from a CD. If you don't have one available check the HP website for support.
Sep 24, 2008 | Compaq Armada M700 Notebook
Compaq Armada V300
or
or
Please let me know.
Jun 26, 2008 | Compaq Computers & Internet
Compaq armada 1580DMT
Sound's like you've had a hsrd drive crash. The message 32768 kb ok is a memory test, this indicates that something went wrong with the operating system the last time it was shut down. It should, after the memory test, either correct the system problem or give an error code. Since it does nothing, this indicates that the hard drive has failed and, unfortunately, needs to be replaced.
Jun 20, 2008 | Compaq Armada 1590DMT Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Memory
you should first download this manual. i believe you need to remove the keyboard....which is fairly simple if you have a small screwdriver.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+E500+and+Armada+V300
Jan 22, 2008 | Compaq Armada E500 Notebook
Error messages
or
or
Please let me know.
Dec 01, 2007 | Computers & Internet
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Hard drive controller
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Compaq Armada M700 Notebook Logo
598 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
