Question about Kenwood KDC-5019 CD Player
Power, but blank screen
I had power, but no response from radio or cd. I pressed the reset button and the radio rotated around and stayed in the horizontal position. I've held the restart, and every button for a few seconds. Still not working.
  • mstanglx Mar 25, 2009
    I had the same problem about 3 years ago, its the ribbon that goes bad that connects the face plate. All the turning and rotating it does causes lots of stress on that ribbbon. I bought the parts from kenwood and replaced them. Ill post the link as solution.
  • Anonymous Apr 16, 2009
    how much is it to fix... i dont think im up for do it myself?
When turning on screen stays black
I have this same model never had a problem with it, test your batteries to make sure they are at least 1.5 volts. Move the batteries to make sure they are contacting the terminals.
not sure if this will work for yours but try it
To perform a master reset:
  1. Turn off the device
  2. Press the PAGE, ENTER2, and POWER buttons simultaneously
  3. Release all buttons once the Do you really want to erase all user data? message appears
  4. Select Yes
Dec 07, 2013 | Garmin Rino 120 2-Way Radio
White screen
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 04, 2012 | Philips SA3CNT16K 16 GB GoGear Connect 3...
Had to disconnect my clio battery and not sure how to reset the radio. I have the code but no handbook so how do I reset the radio ? please
Using the Steering Wheel remote Control
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Jan 03, 2011 | Car Audio & Video
Error code 2
E2-2 No paper (ASF)
Perform an EEPROM reset:
Unplug the printer for at least 2 minutes from the wall.
2. Plug the printer back in but leave the printer turned off.
3. Enter Service Mode
a. Hold Stop/Reset button and the Power button for 5 seconds
b. Release Stop/Reset button but continue to hold Power button
c. Press Stop/Reset twice
d. Release the Power Button
e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
4. Do an EPROM reset.
a. Press the Stop/Reset button 3 times.
b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I need code to radio renault laguna 2001 model no. 22DC279/62Z prod no. FDO101150070013 TOT984 RN279F10070013
Your code is 6018
Philips Renault Code Entry
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct fourth digit
press and hold the [¬ ] button for up to 10 seconds to store the code
Oct 10, 2009 | Car Audio & Video
Screen stays blank when plugged up to charger. Tried pushing off/on button. Been used only twice. Bought new in 2007.
Hello. many GPS's have a reset button hidden under the plastic frame around the screen. look around the perimeter of the screen and you may see a thumb nail ****. Carefully pry off the screen and you may see a reset button. push the reset and hopefully you will be up and running again.
Aug 06, 2009 | GPS
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Renault clio radio
You do not use the buttons.
You have to use the Steering Wheel remote Control
Sep 13, 2008 | 2000 Renault 181
Car radio
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Jun 11, 2008 | Philips Sport Personal CD/MP3 Player
PioneerDEH-P25 problem
i had the same problem once. my solution was i hooked up the radio wrong i wired the red wire and the yellow wire to the wrong wires. i just flipped the wires around and it worked.
Feb 18, 2008 | Pioneer DEH-P25 CD Player
Kenwood KDC-5019 CD Player Logo
250 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
