Samsung LNT4665F screen goes black
It seems to happen only when humidity is high.  Started just before warrantee ran out.  Technician takes it to his shop and it works fine there, so he can't figure out what to replace.
    Brigadier General:
  • 6,966 Answers
Possibly power or heat related issue. A couple of things you can try:
  • when using the Samsung, pls try to temporarily place a blower or an electric fan at the rear of the unit to help improve air circulation. If problem does not appear, then heat related and the tech/shop can simulate with the use of a hot air blower to pinpoint culprit;
  • use a filtered power strip or even a computer UPS with sufficient power rating;
  • plug the unit in a different wall outlet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
  • 659 Answers
Have you thought of purchasing a dehumidifier to take some of the moisture out of the air?
ushally the mini dehumidifers go for around 50 bucks and if place in the general area of the tv it should help with the moisture around the unit.
would have to dump the unit once a day but would be worth it.
  • Wesley Gardner
    Wesley Gardner Sep 03, 2008
    let us know if that works if you decide to try it but I feel thats the only solution to your issue that would make any sence.
    Master:
  • 521 Answers
Due to the moisture on the board, the board short tracks some where and turns the screen black and goes off to avoid further damage.again it will work for sometime and will again go black due to short tracking.the solution for this is to dry your board completely with a hot air dryer and cover the tv to avoid the gathering of the moisture causing the same problem again.nothing to worry it happens most of the time when the humidity is high.dont even think of replacing anything your unit is completely fine and behaving normally.
pls do rate the solution
thanks.
regards.
fixya expert team
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
My dell laptop suddenly started getting a blue screen error and crashing, the error is driver rlqc not less or equal, the laptop is still under dell warrantee is it covered by the warrantee if not how do i...
The Blue Screen Error IRQ Driver not less or equal is a memory problem. Basic things you can do is reseat the memory. However, I highly suggest to contact Dell and have them guide you in doing a Memory Diagnostics. They should replace it if its faulty.
Mar 30, 2011 | Dell Inspiron 1525 Notebook
My Mac G4 Tower, 10.3.9, suddenly lost all color. The display is black/white, shades of grey. When I start to boot up the screen starts blue but then goes to grey. This happened 2 days ago after a nearby...
The wether does have something to do with it. After a lightning storm humidity is a problem. the humidity and heat can make the screen lighter, kind of grey. After the wether clears up it will take an hour to regain full color. Also it could be if it was charging while the storm happened it could have blown a fuse and messed up you screen colors
Also try to gain color by
Control+option+command+8 (negativity)
Control+option+command+< or >
color tinter
Jun 27, 2010 | Apple PowerBook G4 Mac Notebook
Samsung HP-4252 screen goes black
I have the same problem, and it will get worse. I have read and seen video on youtube, stating that it is capacitors on the power board, that need to be replaced. I watched the tutorial video it seems pretty easy, I am going to try it this weekend. Will update.
Jun 02, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung LNT4665F, small red dots on LCD screen when powered on
i've seen this several times. the power supply board is starting to fail. next symptom will be it will not turn on. call 1-800-samsung for nearest service center.
Dec 07, 2009 | Televison & Video
A few popping sounds and multiple on and offs for my Samsung
you have a bad capacitor in the power supply the can shaped device will have a puffed up or domed top, when you find it replace it with the value printed on the side
Some water leaked down the back of my 42'' lcd samsung and now half the screen is black , initially the screen was fine then i got 1 black line then 2 and so on untill half was solid black , will the...
Yes. There are small adhesive indicators which are placed inside of the television which change colors once exposed to water or high humidity. Normally from white to pink. Same goes for modern cell phones.
Dec 02, 2009 | Televison & Video
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Monitor goes to sleep after hackers attacked..
This is the way how to check what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | SAMTRON 77V 17" CRT Monitor
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
