Question about GE Microwave Ovens
When running my GE microwavem oven jes1036 the oven will stop and "pf" comes on the screen.
  • GE Master
  • 9,098 Answers
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Sep 16, 2008
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
I have a GE Spacemaker XL1800, about six years old. It heats food fine, but there is a terrible grinding sound while it does so, for the entire time it is running. This has been going on for several...
Personally, I would replace the Microwave. It is bound to be below specification by now if it has been used quite a bit.
Then you will know you will be fine for a few years.
Dec 15, 2010 | GE XL1800 1100 Watts Microwave Oven
We have a relatively new (about 6 weeks old) GE OTR microwave--model is JVM1540SP1SS. Yesterday it started "running' even when there isn't any food in there and before we push any buttons. When the...
It sounds like a sticky door switch. There are several switches operated by the door latches to keep the oven from operating with the door open. It's possible someone got a little too rough when closing the door, which can cause misadjustment.
Since the oven is so new it will still be under warranty, though. Why not let GE fix it? You just need to tell them it's not working properly. First call the retailer where you purchased the oven. If they arranged installation they probably also handle service. Otherwise you can contact GE's customer service as instructed in your owner's manual to find out how to handle the repair.
Nov 28, 2010 | GE JVM1540SMSS Microwave Oven
Hotpoint GE Household Microwave
Well, I think you should get a brand new one.
They do not cost as much to replace these days and it might be safer.
May 11, 2017 | GE Microwave Ovens
My GE microwave started running by it's self. It first said 3.5oz and would not stop until door was opened. then it started beeping and wouldn't stop until door was opened. we unplug hoping it would reset...
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Dec 10, 2009 | GE JVM1440 Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Was cooking in microwave and it totally shut off. Light went out and stopped. After a while "PF" appeared on the panel. What caused this to stop and what do I do to get it back working? My...
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
First of all, be sure the internal cooling fan is running. That's critical to protect the magnetron by keeping it cool.
You can test this by running the microwave with a cup of water inside. First, cook for about 2 minutes on the lowest power setting and see if it makes it to the end. Then cook on high for 2 minutes and see if it makes it to the end.
If the defrost test works, but the full power test does not, then the magnetron is overheating.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | GE Microwave Ovens
Microwave Ovens Logo
133 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
