Question about La Crosse XG-55 Wrist Watch
Setting the altimeter on the la crosse xg-55
How do you calibrate the altimeter for the la crosse xg-55? I'm currently at the ocean and the altimeter is reading -163 ft.
  • Anonymous Mar 25, 2014
    battery reset
Altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
Is watch dead or is battery dead
If your numbers dim when you push any button, it's probably a battery. If your numbers are off or very faint same problem, battery. Those watches take a 1.50 V cell because of the light, and multi functions. Any decent jewelry store should be able to have you in and out in 10 minutes or sooner.
Good luck, gabe.
Oct 22, 2015 | La Crosse XG-55 Wrist Watch
Hi my xg-55 froze up, how do I fix it
You will need to take this watch in to a local Certified Master Horologist. It will have to be opened and reset from the inside by shorting the appropriate contacts on the movement. It may also require a battery to operate properly, if it has not been replaced in the past 1-2 years.
If you wear this watch in the water, you need to have it pressure tested to ensure its resistance after the procedure. This is properly done with a pressure testing machine that usually is found at Horologist / Watchmaker shops only.
Feb 04, 2011 | La Crosse Watches
Lacrosse xg 55 - Do I need to replace the battery? When I use the light nothing displays is this a battery issue? How do I change it if it is the problem?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
Jul 16, 2010 | La Crosse XG-55 Wrist Watch
Changed battery now it won't come on
Try shorting the battery case to the watch chassis (using a pair of tweezers perhaps).
This seems to be a standard instruction and I think this resets the watch.
Apr 24, 2010 | La Crosse XG-55 Wrist Watch
How do you calibrate the compass for a Lacross XG-55 wrist watch
Here is the manual for your watch. It tells you how to calibrate the compass. Print out the manual and keep for future reference.
http://www.lacrossetechnology.com/xg55/manual.pdf
Good luck. Did this help you?
Jan 12, 2010 | Watches
Can not seem to set my altimeter on the ws4 timex i have tryed do this but it is giving me the wrong hight ? and know one in the shops can figger this out to????? what am i doing wrong iv tryed to folow...
Setting and Calibrating Your Altitude
1. Press MODE until CAL is shown.
2. Hold SET to begin the calibration.
3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather).
4. Press MODE (NEXT) to begin the setting process.
5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values.
6. Set the value to your current elevation.
7. Press MODE (NEXT) to advance to the next setting option.
8. Press SET (DONE) to finish.
9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
Jan 05, 2010 | Timex Watches
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
1. Activate Crystal
2. Press Altimeter
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Owner manual
Go up a level, then select your model.
http://www.gsi-usa.com/instructions/
I found my Coleman 40-842 there.
Sep 15, 2007 | Watches
La Crosse XG-55 Wrist Watch Logo
381 people viewed this question
Top La Crosse Watches Experts
Starnley Johnwells
Starnley Johnwells
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
