Can I use the Fun! Flash 640 SE camera with Windows XP?
Is there any way I can use my Fun! Flash 640 SE camera with my Windows XP computer? I get an error message that says the software is not compatible with Windows NT.
Exactly the same problem. The only difference is my camera, while a 640, does not exactly match the specs on the page. I have an LCD screen.Exactly the same problem. The only difference is my camera, while a 640, does not exactly match the specs on the page. I have an LCD screen.
You can't post conmments that contain an email address.
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
I have three different digital cameras. I use the scanner and camera wizard to download my pics.
The second option, if you use SD card with your camera, then you can get a USB 2.0 SD Memory Card Reader/Writer.
A 9-pin serial connection must be available on your computer to connect a PhotoMAX Fun! Flash 640 digital camera.
This camera model does not have a USB driver, so a USB-to-serial adapter will not function properly.
Windows 2000
A new camera TWAIN driver (version 0.1) compatible with Windows 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible.
NOTE: In order for the version 0.1 driver to work correctly, the PhotoMAX software must also be compatible with Windows 2000.
The PhotoMAX SE software originally included with the Fun! Flash 640 is not compatible with Windows 2000.
If you use your camera and computer with the original PhotoMAX SE software, contact the Polaroid Parts Department for more information about purchasing a PhotoMAX software upgrade.
Windows NT4
No TWAIN driver is available for use with Windows NT4.
None of the Polaroid digital cameras listed below can be used as a
"web cam." All of these models are designed for taking still images only.
DMC/DMC 1e
DMC2
Fun! Digital 320
Fun! 620
Fun! Flash 640
Fun! Flash 640 SE
Fun! Flash 820
MP3 Digital Camera
Olympus C-211Z
PDC 300
PDC 640
PDC 640CF
PDC 640M
PDC 640 Plus
PDC 700
PDC 800
PDC 1100
PDC 1300
PDC 1320
PDC 2000/3000
PDC 2300Z
Check to see that the On/Off switch is in the On position.
Check to see that the green power light on the back of the camera is lit. If it is not lit, make sure that the batteries are loaded properly. If necessary, insert fresh batteries and try again.
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
