Question about JVC DR-MV7 DVD Recorder/VCR
JVC DCD Recorder hookup to digital TV
I hooked up my JVC DVD Recorder/video cassette recorder to my new digital TV, and when I hook it up according to the manual, I cannot access my digital stations. Probably because the recorder is analog. I tried using a cable splitter, but I don't think it is right either. Any ideas?
  • 8,596 Answers
Yep, this recorder is NTSC analog. Sad, too - it was only manufactured in 2006 - they knew about the digital transition then. There is a possible workaround, but it depends on your TV - if your TV has a red, white AND (most importantly) yellow OUT/OUTPUT, then you can hook it to the AV IN on the back of the JVC and record from TV that way. Note: most TV's (even new ones) do not have the yellow video/monitor OUT, even if they have red and white audio OUT's.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
How to hookup and use
A DVD recorder can hook up to any TV that has at least a set of AV inputs (you will need an RF modulator if your TV does not have AV inputs).
Just hookup your cable or antenna feed to the ant/cable input of the DVD recorder and loop it out to the RF input on the TV.
Nov 13, 2011 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Jan 18, 2010 | JVC Televison & Video
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Cannot get new DVD recorder/video cassette recorder to work .Hooked up to t.v. with comcast on-demand box. help
if u hook it up thru comcast i think u have the recorder on the wroung. or if u are using video inputs u need to make shure that u are using the video out source from your comcast and u are going to video input on your dvd and then u should be just find because if u have it hook up right thru the dvd u will get a picture thru the dvd from comcast i hope that helps u
Oct 12, 2008 | Televison & Video
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
DVD-R120 hookup for recording
You will have to hook up your recorder directly to your TV or use as a stand alone recorder.
Other possibility is to buy a 2 way video switch. This will allow you to hook up two video machines to the same input jacks on the RCVR. You just swith between the two devices manually.
Radio Shack usually have these input swithches under $30.
zucktucker
Dec 09, 2007 | Samsung DVDR120 DVD Recorder
JVC DR-MV7 DVD Recorder/VCR Logo
240 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
