Question about NEC MobilePro 750
External VGA controller
How do I get the External VGA controller to work on my Mobile Pro 700/750?
    Master:
  • 903 Answers
The VGA adapter is only for use with Pocket Power Point: 1. Open a PowerPoint presentation. 2. Go to the View menu and select External VGA on the View Show On drop down menu. 3. To make the presentation display automatically, under Advance Slide choose Automatic and enter in the amount of time in seconds between slides. 4. Say OK to that screen, then go to the View menu again and select View Show and now the presentation should display on the VGA monitor in 640x480 and 256 colors.
Posted on Sep 14, 2005
SOURCE:
Im trying to connect my laptop to my TV, laptop end is a VGA and tv is HDMI. i also have a cord that does VGA on laptop Component on TV..neither will work.. whats the problem?
Hey Erin, when you mean it does not work as in there is nothing on the screen including audio? With VGA to HDMI (assuming you have the VGA to HDMI adapter) you should only get video since VGA does not support sound. As far as connecting goes its pretty much plug and play. That's also assuming that you have set it to the correct input on your tv and make sure your laptop has proper settings. Go to control panel and go to display. Make sure it recognizes dual monitor. Other than that there really should not be a problem. Look at video input on tv and display settings (OR mobile pc > windows mobility center > connect to a projector or other external display (not under classic view - Vista). I hope this helps. Give me a feedback if not. Good luck Erin.
- Joe.
Oct 22, 2013 | Televison & Video
Video on my toshiba L455=s5009 comes on for a few seconds then blacks out
From your brief diagnoses stated, it sounds like a bad Video Cable.
The Video Cable routes from the motherboard, across one edge of the Fan Assembly, and under the left Hinge assembly,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/big-body/laptop-disassembly-19.jpg
With just the usual opening, and closing of the laptop, the Video Cable's sheath may be damaged. This means the tiny wires inside the sheath may be damaged.
(Stretched/Broken)
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-Pro-L450-L455/laptop-disassembly-1.htm
http://www.laptoprepairparts.com/html/details.asp?ref=1860&category=cables
Or it may be the screen Inverter that is damaged, or going out,
http://mcccomputers.com/shop/lcd-inverters/3666-new-toshiba-satellite-l455-s5009-l455-s5045-lcd-inverter-pk070006t20-k000087330.html
Or the LCD screen assembly.
Could be the graphics chipset.
Diagnose.
1) Laptop OFF, monitor OFF, connect an external VGA monitor to the laptop's VGA connector, on the back of the laptop.
[ RBG (Monitor) port ]
You can use a CRT monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable, for the external VGA monitor.
[ Example of a VGA cable, and a VGA port (Connector),
http://en.wikipedia.org/wiki/VGA_connector ]
Turn the external VGA monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the external monitor should show the display, also.
IF not;
1) Press, and hold down on the Fn key, and simultaneously tap on the F5 key. (The F5 key is the Display toggle-over key)
Not showing on the external VGA monitor? Perform the above procedure again.
There are several display options.
External VGA monitor also show the same symptoms?
Bad graphics chipset. Replacing the motherboard is the most cost effective method, and easiest method.
External VGA monitor does Not show these symptoms?
Problem is the Video Cable, or screen Inverter, or LCD screen.
Due to movement of the LCD screen, which means movement of the Video Cable, my money is on a bad Video Cable.
(A Video Cable can be unplugged partially, real easy, on the back of the LCD screen.
It MAY look plugged in tightly, but may not be.
It can also be unplugged real easy when assembling the Display Assembly, to reinstall back on the laptop )
Check the Video Cable's wires with a multimeter. Perform a continuity check of all wires in the cable. (Multimeter set to Ohms)
Have an assistant also gently wiggle the cable, as you are testing. See if there is an intermittent break, due to a stretched/broken wire.
Or just buy a replacement Video Cable, and use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 04, 2012 | Toshiba Satellite L455-S5009 laptop
THE MONITOR ON MY ONE PIECE GATEWAY PC IS BLACK BUT THERE IS POWER TO THE COMPUTER. TRIED PLUGGING IN AN EXTERNAL MONITOR BUT HOW DO I GET IT TO WORK WITH THE COMPUTER?
Addressing this as a Gateway 4540GZ PC Notebook. If it is a different computer please state in a Comment.
Gateway Support > Gateway 4540GZ main support page,
http://support.gateway.com/s/Mobile/Gateway/4536GZ/4356nv.shtml
User Guides > Click on > 8510221-Gateway Notebook User Guide
Page 31 - System Key Combinations
Press the Fn key, and the F4 key to toggle over to an external monitor.
(External monitor plugged into the VGA port on the back of the laptop, and turned on,
VGA port,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Nov 02, 2010 | Gateway 4540GZ Notebook
How can i connect the macbook pro into an lcd projector, which adapter should i use....?
what are your options on the projector side?
Your Mac comes with a DVI (Digital Visual Interface) port.
Attach the DVI to VGA adapter to the VGA connector of the external monitor.
depending on the external monitor/projector, you may need different adapters.
Sep 11, 2010 | Apple MacBook Pro Notebook
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
No video output on IBM Intellistation PRO M, model 34G. How do I figure it out? Replaced vci card with pci vga card.
To confirm if your external vga card is defective you should turn off your pc then remove it, then turn it back put your vga cable from monitor in the built in vga port in you pc. or else after turn on press numlock twice or more if its work then external vga is the problem.
Nov 19, 2009 | IBM IntelliStation M Pro 6219 PC Desktop
No vga driver for amilo pro v2030
You can find the driver link here. Amilo Pro v2030 VGA Driver scroll down and you will find the link "VIA/S3G UniChrome Pro IGP". you must register first to download the driver. Just use free Membership in signing in and just skip or select no thanks in other membership offer..
Hope I Can Help
CLCTECH
Apr 28, 2009 | Computers & Internet
Secondary monitor from a Laptop
If your laptop doesn't automatically detect the external monitor, there will be a function key you need to press to activate the external monitor connector. It's often on the top row of keys, but different manufacturers put their function keys wherever they like. The key will normally have a marking that looks like a little monitor screen. Connect your external monitor, hold down the F or Fn key and press the monitor key when you find it. Usually the first press will turn on the external monitor and turn off the laptop screen, then the second press turns the laptop screen back on. Some brands or models may not turn off the laptop display, though.
Feb 10, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Screen gone wild
If your external video is working, most likely your VGA controller is good. Your laptop is using the same controller to control internal and external video. It could be two things that would cause your problem:
1. LCD VGA cable that connect your LCD to the laptop
2. Bad LCD VGA connector on the board(cold soldered joints)
3. BAD LCD panel
Any of the following repairs will require disassembling of your laptop.
Regards
May 27, 2008 | Acer Aspire 4520-5582 Notebook
Nx 5000 dual screen problem
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Feb 08, 2007 | HP Compaq nx5000 Notebook
NEC MobilePro 750 Logo
723 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
