Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson CX 7400 WONT LOAD PAPER
I have an Epson CX 7400 and it wont load the paper.It acts like it wants to but it wont load.
  • 5 more comments
  • radkfloyd Sep 03, 2008
    I have tried one sheet and several.It wont load paper.Has anyone else had this trouble? Please help me!
  • steven1959 Sep 16, 2008
    i bought an epson stylus dx4450 before i left Holland. i unpacked it in oman, and guess: there is no way to load it with paper. maddening? And now I can't even go back to the shop.
  • greggz
    greggz Sep 21, 2008
    i load the paper as it says on the instructions but it just wont print with it. you just hear it attempting to load it but nothing happens!!! :(
  • jfer101 Dec 02, 2008
    won't load paper
  • gayle_castel Jan 21, 2009
    i have just purchased an epson sx100 where the hell do you put the paper as no instructionc came with it ive tried the back
  • Anonymous Jan 22, 2009
    I have just bought an sx105 with paper loading instructions with it but it just will not pick up the paper. makes a noise as if it is trying but I can see no way that the paper can be fed through
    anyone out there had the same problem
  • Anonymous Feb 01, 2009
    Bought Epson SX100 - There are no instructions how to load paper. What kind of a disorganised company is this. How do you load paer in it?
I had the same problem. If you call Epson, they will send you another printer out. I did this, and they didn't even ask me to send the old one back. You do have to have the serial number handy though. My suggestion is to call Epson.
Posted on Oct 21, 2008
Hi dear,
I had exactly the problem, I had to remove the top cover & second base out of it , and i found 1 paper jam on the side, it's stucked under control panel,( it's on left hand side, look from the front to back) it was jam on some gear dow there, i just took the jam paper out and bouble check, make sure all gear are clear and i install all back on and tested, it's working find. I hope you do the same like i did and no more problem. Goodluck to you. Also i hope this messenger is not too let to you. Because my son he own this printer and he throw away when it had problem, and than i took it back and fix it. it's working like new now. If you until need more help please do email me at westone2008@yahoo.com we'll work from there. Good luck.
Posted on Mar 16, 2009
    Problem Solver:
  • 18 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
aqq-14
Posted on Sep 03, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: Epson CX 7400 WONT LOAD PAPER
The reason: number one it is an Epson and all their printers have very weak plastic gears in the paper loader mechanism that break easily when you unjam a paper jam. You have to treat these printers like fine China. That is why you see allot of Epson printers Refurbished.
Buy a Canon if you want at least three years of no problems with their paper loading mechanism. Almost any other printer manufacture builds a better printer than Epson, Sorry for the bad news.
Usually you just buy a new printer when you have these paper loading problems, also try to see if the printer is jammed still with a piece of paper, or maybe some dirt or lint and hair, blow it out with compressed air and make sure the rubber roller paper feeder is turning, if not then you can buy a new printer for cheap these days. Usually a new printer cost the same as the replacement ink for the printer, so buy a new printer. Printers now a days are disposable especially Epson.
Posted on Feb 26, 2009
My epson sx535wd printer will not feed my photo paper through the second feed to print
My 535 wont load 4 x 6 photo paper and has not done from new, i gave up in the end as chasing around trying to find an answer was nearly impossible.
Dec 16, 2012 | Epson Stylus Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Epsom tx110 wont feed paper
Hi!
Try to check for any obstruction. Fan the paper as well on the paper tray. Closely check the mechanism as well when it acts like grabbing the paper. If all fails. Call Epson for a replacement.
Hope this helps.
Oct 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
Ink cartridges are all full, but when I print, it acts as if it's printing but nothing appears on the paper.
  1. Turn off the Stylus CX.
  2. Load letter-size paper in the sheet feeder.
  3. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds.
    The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Whats going on with my printer
Replace paper feeder. Or find at aicaxz solutions about fixing paper jam without replacing.
Sep 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Computer keeps saying "paper out" or "not loaded properly"
disconnect the printer from the computer
do a manual paper feed
if it can feed paper, replace usb cable or try another usb port
May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
581 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
