Question about Canon PowerShot Pro1 Digital Camera
Camera won't turn off
Today my Canon Pro1 refused to go into playback mode, then woldn't turn off. Finally had to remove the battery to get it off. anyone have this problem, this is the first time it has happened, I have used it since June. thanks
  • inkyfingers Dec 03, 2007
    I'm about to return this pro1 to future shop thanks to buying the 3 year warranty!! Love this camera "when it works" but lately it turns off by itself after I shoot (with a full battery) and I have to take the battery out to turn it back on. Then it will turn itself off again after I shoot and obviously I have lost the photo. I have not seen anyone else's complaints like mine. Very very frusutrating!! My powershot is almost 2 years old. I found it odd that canon only kept it in inventory for a year before replacing this model.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
It probably had a problem with something which entered the back of the lens and the lens stuck outside.
Posted on Aug 24, 2008
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Trying to upload photos to my Apple computer. Does the Canon have a setting for uploading photos?Thx
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 20, 2012 | Canon PowerShot Pro1 Digital Camera
Cannot delete pictures from camera,says they are protected
Check the card to make sure the little tab on the upper left side is not in the down (lock) position. If not, look at the pictures in playback. If they show a key, then you will have to unlock them in the playback mode. there is an unlock option in the menu. You will have to unlock each one.
Mar 13, 2010 | Canon Power-shot Pro1 Lens Converter
When trying to download pictures from my Canon Power Shot A590, I get an error message saying the camera cannot be found. The software is ok (I can download from another identical camera). The camera is...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 30, 2010 | Canon PowerShot A590 IS Digital Camera
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
It probably has a battery that can't hold a charge to it and needs to be replaced. Those batteries can be purchased at Canon using this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=256&modelid=9823#SNAModelSuppliesAct
You might be able to find a less expensive one on EBay, Radio Shack, or Batteries +
Jun 21, 2008 | Nikon COOLPIX L3 Digital Camera
Canon powershot pro1 will not turn on
You have to try another battery to know for sure if it is bad. I have three batteries so that I can rotate while I am working with the camera.
Jerry G.
Nov 15, 2007 | Canon PowerShot Pro1 Digital Camera
Canon dvd camcorder DC210
Ok, Guest @ solution #1 and #3 solved this for me.
Step 1. remove battery pack.
Step 2. Plug in to outlet.
Step 3. Insert desired disc.
Step 4. Toggle down on the "mode" lever for "Play-back" mode.
Step 5. Press "function"
Step 6. Scroll to and select "menu"
Step 7. Scroll to and select "disc options"
Step 8. Scroll to and select "Finalize"
Step 9. Scroll to and select "Yes"
Follow prompts from there.
This worked for me.
Thank you all!!!
Sep 23, 2007 | Canon DC210 DVD Camcorder
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
