Question about Intel Motherboard
Sony comp issue
I wanted to thank you for your help, it was helpful and i learned a lot
although the computer doesn't seem to be working, even after I've pressed F11, i think that the problem lies within norton, and i figure i'm going to get a recovery disk and redo the computer, even if most of my information is lost. I wanted to know, however, what were the free sites for the virus protection, so the in case the recovery works, i know not to put norton but something more reliable. But thanks again for all the information!!!
    Sergeant:
  • 226 Answers
I'll be happy to help. Malwarebytes is very new and seemingly very reliable program that scans for malware, spyware, virii, and does one heck of a good job doing it. Does not have to be registered as long as you don't need the Protection Module which in reality very few people need and so as a result is free for use. It also is very fast comparatively speaking compared to most other malware scanners. Another is SuperAntiSpyware ( get the FREE version, it is all you need ), it's is a bit slower then MalwareBytes, but works well in conjunction with Malwarebytes. Suggest you install both, scan and clean if you suspect any activity that seems suspicious and even if you don't suspect any activity as many malwares lie dormant and unnoticed by most antivirus programs.
The antivirus of choice in my opinion is AVAST HOME FREE, not the AVG that so many people are tricked into downloading because it is advertised so heavily. I've been using Avast for over 4 years now with no complaints, but as with all antivirus products I have tried, malware will sneak around it. And so the need for a the Malware scanners above as once the Malware scanners engage and starting doing what they do so well, a good antivirus will jump right up and join in the fight against the malware/virus. It's a beauty to watch all three programs going after an infection.
Now after the first scan and clean, reboot the computer and do the scan and clean at least one more time for comparisons sake and to allow some confidence in the better operation of the computer. Don't be afraid to do this more then twice if you feel you need to as it shouldn't hurt anything on your computer and should leave you with a computer that almost runs like new asssuming your only problem was a malware/virual infection.
Avast Home Free initial download give you 60 days of free updates, but a FREE registration gives you the next year and can be re-registered each year for free. Like I said, been doing for 4 years plus now. Website will explain registration process, simple as pie and you will love that fact that you did. I don't work for Avast, I just appreciate good software.
Personally if I were you, I would run this software now before doing a restoration just to see what it might find. Restoration of a system especially a Sony system is a long tedious operation best avoided if at all possible. Make sure you only have ONE antivirus product on your computer at a time as having two will cause conflicts and huge performance drag on the system as both antivirus products would be trying to gain independant access to files for scanning. Not a pretty sight and a huge P.I.T.A.
If you have problems de-installing Norton, come back as I will give you sites that will address that issue with Norton.
Posted on Sep 03, 2008
  • Ravel Lively
    Ravel Lively Sep 03, 2008
    Now back to ' computer not working '. It is very easy for me to get off on a tangent and end up missing the initial problem. Problem with being only one-eyed and somewhat overly-technical. Let's talk more about the original issue. You mentioned beeping twice and I told you that if were the case I would have to look up the Bios beep codes for your model and that required knowing for sure exactly which Bios producer was used in that computer.
    Are you getting any displays whatsoever, even in white tesxt on black background ( Dos-like ), initial boot of the machine?????.
    When I looked up Bios beep codes, I saw no mention of two beeps only, but I did see mention of two short beeps and a long beep being a video problem, so we need to exact when talking about bios beep codes. Not to much room for error here. A single short beep is normal and indicates proper posting of the bios during boot, i.e. hardware and firmware good.
  • Ravel Lively
    Angelkat, do you know how to get into your Bios setup? Use F2 very early right after power-on. Click it a couple of times and the system should go into the Bios setup routine. You will probably have to do this possibly several times to get the hang of how to do it. When in the Bios setup, hit F9 ( sets Bios to computer factory defaults ), then F10 ( saves the Bios configuration ), then Exit which forces you to save again, just say Yes and you will exit and hopefully the computer will boot normally and without incident.
    Sometimes this will fix a memory mis-configuration due to memory being added to the system. However if you have a true hardware issue with memory, video, or any other component, it will not do any good. However doing this might lead to a better idea of exactly what is wrong as different bios beeps might be indicated. Listen for short beeps and long beeps, and remember one short beep is normal meaning you should get a display in a matter of two to ten seconds at most.
Want to Learn how to create web pages?
It would be really good if you could what problem are you facing.
However at first go, My suggestion would be you go to w3schools.com and learn HTML5,jquery,bootstrap this will help you design the way you want in very intuitive way. Once You are through on that then only go for PHP+Mysql
Mar 21, 2015 | The PHP Group Computers & Internet
I want to replace the throttle control sensor, and I want to know if I unhook the sensor is that gonna cause a computer malfunction or should I take off the terminals to the battery?
Repair manuals always say to take the negative terminal off before working on electrical parts. You only need the negative off, not both.
Actually, it wouldn't cause a malfunction (unless it maybe had a bad short), although it might set a trouble code. But that could be erased. I have heard that many mechanics are reluctant to take battery offline on lots of newer cars, unless absolutely necessary, due to issues with computer re-learning processes. When the car leaves the shop, customers complain the car is not running right, but if battery was disconnected, the computer may require several drive cycles to re-learn its former performance.
Feb 23, 2012 | 1998 Cadillac DeVille
Insignia NS-27LCD TV, got a nasty static shock, and now I just get a blinking red light on the front. Nothing else happens...I left it unplugged for a year (yes, a year lol) and I am still having the same...
Jason, this does sound like a main unit issue...although not 100% certain. Give a company named ShopJimmy.com a try for parts. They have been a huge help to me in the past. I included a link to your model page from their site. Hope that helps!
http://www.shopjimmy.com/catalogsearch/result/?q=NS-27LCD
TeeVeeMan2@gmail.com
Sep 21, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KV-40XBR700 40" CRT WEGA
I too would like to know the solution to this question...we are having the identical problem and Sony doesn't seem to know how to fix it. Although, the picture from the DVD player is perfect, the pictures for cable & video games are terrible. Very frustrating!
Aug 24, 2011 | Sony KV-40XBR700 40" TV
My Break, ABS and Trac warning lights all come on at the same time. I can shut the engine down and restart the issue goes away. I t seems to be happening more frequently. My mechanic found nothing wrong...
Nothing wrong. Doesn't that seem strange to you
The ABS & Trac came on because that system has issues
There may be stored data, if not a code present
The mechanic has to component test to find the problem
These guys spend too much time with a scan tool & I
think some of them are waiting for it to tell them something
Doesn't work that way. If everything goes as it should, the
scanner shows what the computer sees,that's all,& that can
be a lot,but you have to move on & use different skills that
not everyone has learned yet apparently
Try another shop
That really isn't a diagnostic test etc,just looking at data
stream,if they see nothing out of range they quit
That doesn't help you any,the problem is still there,intermitent
maybe, but there.
Jun 26, 2011 | 2001 Ford Windstar
I want learn the laptop repair
Thank you for using fixya.
I am glad that you want to learn how to repair a laptop. Learning on how to repair a laptop needs time and effort. Computer world is really a big wide world and there are a lot of things that you need to work on before you can repair any problem. I can help you learn on how to repair a problem in your laptop but I need to know first what's the problem enable for me to provide you with the steps on how to do the troubleshooting.
If you want to learn everything about fixing a computer, you need to understand the parts and all about computers. Going to a computer school is really advisable.
Cheers!
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 03, 2011 | LG X-Note LM50 Notebook
White screen flashes up
You need to hvae the phone firmware reflash on the phone to correct this issue....you can try at topsony.com or take it to a mobile service center close to you to have that done.
May 26, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Driver
hi to everybody
i want to connect my k-jam too my desktop but the win7 doesn't recognize it.
what should i do?
send me a email.
lots of thanks
Jul 15, 2008 | i-mate K-jam Smartphone
Intel Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
