Question about Motorola Cell Phones
My motorola razr2 v3 won't start. It ran fresh out of battery power, then after charging it, it no longer boots up beyond the the initial motorola "M"blem. The outer screen is blank, but still vibrates when touched along the bottom.
  • 18 Answers
You are definately going to need to call your cell provider to see if you can get a new phone..because it sounds like the phone may be bad.
Posted on Sep 03, 2008
Won't go on I've pressed the key it lit up when charging
The battery may no longer be able to accept a charge. Try a new battery in it and charge it before seeing if starts to work as expected again.
Oct 23, 2015 | Motorola Mobility RAZR V3
My motorola motor razr2 when i put charger in it starts to charge and phone turns on and green charge light goes out and it stops charging
ok this can be numerous things lets start with slide the charger cable out gently see if at any time it starts charging as you do this. No 2 could be the battery getting week, and loosing a cell in it. No.3 this is a software glitch that the phone needs for the software to be reinstalled which will take a technician familiar with modding and software.
Jun 19, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola razr2 v8 phone will not charge battery. Works on pc but now even that has stopped working.
REMOVE BATTERY
REMOVE SIM CARD
INSERT BATTERY
INSERT CHARGE LEAD
PUSH * & # TOGETHER - HOLD FOR 1 MIN
SHOULD START CHARGING - IT DID FOR ME!
REPLACE SIM CARD WHEN FULLY CHARGED QED
Mar 30, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Motorola RAZR 2 small amount of moisture got behind battery cover
the key board can be replaced..just be careful of the flat ribbon cables as they tear easally
Nov 14, 2009 | Motorola Mobility RAZR V3
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
V3 formatting
press menu
select setting
intial set up
master clear enter security code'
default is (000000)
after re-boot
same procedure
initial set up
master reset
enter security code again'
wait until tha phone re-boot
your phone is already formatted'
all media,phonebook entries, will be lost or deleted.
and make sure you are fully charged.
Nov 01, 2008 | Motorola Mobility RAZR V3
Razr V3x
The internal phone software needs to be "reinstalled".
Take it to a service center, they'll know how to do that. The phone will not charge, will not power on and will not accept any input from the keyboard or the USB port except the correct software.
If you try to reload the internal firmware by yourself (there are guides in internet telling how to proceed) be aware that you can render the pone useless beyond any repair.
May 02, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
51 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
