Touch pad's function of scrolling vertically and horizontally is not working. All the other functions are fine.
  • sspml Sep 03, 2008
    thx, i'll try that
  • 3,940 Answers
The touch pad drive needs to be installed. XP will provide basic function support for a touchpad,. Advanced features require the specific discrete driver from the manufacturer
Posted on Sep 03, 2008
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
Touchpad must be continually tapped to make scroll bar scroll up or down
Different laptop uses different type of touch pads. If your's an old laptop, that may not have a scroll function by simply sliding your finger through the right edge(top to bottom and vise versa) to scroll to a desired level. A new laptop has all these functions. Go to the control panel click on classic view in the left pane in case of xp and vista. Then you can see the mouse icon.click on it and select the device setting tab. then click on setting and a new window will open.There click on scrolling and click on one finger scrolling you can see the scrolling properties. tick mark the vertical and horizontal scrolling boxes. click apply then ok and close all the way. Thats it All done. Hope it helps
Dec 02, 2012 | Computers & Internet
Vertically and horizontally finger scrolling on my vaio laptopnw series is not working any more or maybe i have deactivated it,i had a touch pad icon on my toolbar hiden icons before ,but not anymore.how...
Hi sheki_68,
If you have disabled the Scrolling Feature of the Touchpad, you will need to re-enable for the function to work correctly. You can enable the Touchpad Setting from the Control Panel, Mouse Options.
  1. Click the Start button and then click Control Panel .
  2. In the Control Panel window, click Hardware and Sound .
  3. In the Hardware and Sound window, click Mouse .
  4. In the Mouse Properties window, click the Function tab.
  5. To enable the Scroll function, click to check the box next to Use Scroll Function.
  6. Click the OK button and then close the Hardware and Sound window.
This should re-enable the Scrolling Feature of the Touchpad. If the Function is not available in the Mouse Properties window, you may need to re-install the Touchpad Driver in the Computer to fix it.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 20, 2010 | Sony VAIO NW270FS Series 155" Notebook PC
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
Can not grab and scroll with my vertical and horizontal touch pad
Go to Dell.com and download the driver. http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=149404
Jan 18, 2009 | Dell Inspiron 9300 Notebook
I have lost the ability to scroll using the right vertical edge of the touch pad. Otherwise the pad works fine but it is annoying not being able to scroll any more without moving the cursor to the 'scroll...
The option to enable or disable the scrolling option for the notebook touchpad is generally available by going to the Control Panel, then selecting Mouse. Within that area, go to Device Settings, select the touchpad from the list of available devices, then click Settings. There should be an option for "virtual scrolling" - click on it, and you should be given the options to turn on or off both horizontal and vertical scrolling for the touchpad control.
May 06, 2008 | Computers & Internet
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
