Question about Canon imageRUNNER 210S Copier
Error E007-01 switch main off and on E007-01
    Problem Solver:
  • 11 Answers
This error is comes heater problem.open front door. see near counter small hole is here insert one small pin and press service mode is on u see disply $ then press * and touch * function* err then o k machine off and on this error is gone. return this error come u see u r machine heater section film is unposition correct it or change it
Posted on Oct 01, 2008
  • subbiahgo475 Jul 30, 2011
    This answer is Very Useful to me. Thank you
    By
    Gopalakrishnan
    G.K.Internet & Xerox
4 Suggested Answers
  • 412 Answers
SOURCE: Canon GP 225 - Error code: E007-01
This can be either of three main thing.
1. The machine detects the film out of place and needs to be reset, you do this by activating the service mode. Insert paper clip into hole (inside machine), then * * and service mode shud activate, then click error code and clear all errors.
2. The film is out of place, the fuser needs to be removed and the film manually moved back to the hope position
3. The film is torn and needs to be replaced (LONG WORK AHEAD)[/code]
Good Luck!!
Posted on Mar 18, 2009
SOURCE: Error Code E007-01 on Canon CP-200 Copier
Fixing Assembly needs replacing.
Posted on Sep 15, 2009
  • 170 Answers
SOURCE: Switch main power on and
the error e007-01 is from fixing assembly you must need to check the fuser film maybe its worn out if its worn out replace a new fuser film to remove error
Posted on Dec 11, 2010
What is a flashing F23 Error
blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Nov 12, 2014 | Whirlpool Duet Steam WFW9700V Front Load...
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
I have samsung and it displays l5
If it is E2 15 then it may be a switch error (Main Relay error) Check for stuck button switches or power button switch for sticking. May need to replace the main PBA. Verify the error and provide the model number to verify the error code specific to your model.
Aug 28, 2012 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
Feb 03, 2011 | Canon imageRUNNER 2200
Have 2 IBM 9068-A01 Dot Matrix Passbook Printer. Both are showing Errors. There is no paper-jam and I have installed 4 different Ribbons, still no joy. First Error code is 0F and the second Error code is...
The cover is not shut all the way or the magnet is not making the connection between the cover and the chassis. A1 is a microcode checksum error. don't know what that means.
Oct 28, 2010 | IBM Network Printer 17 Laser
Error c3451
this is a fuser temperature too low error code could be the thermistor or heat lamp is not comming on to reset the error code turn the main switch off the main switch is located on the left side opf the machine towards the rear and while holding the utility/counter button down turn the switch on hold the utility /counter button down until trouble reset appears on the touchscreen then release theutility button and touch the trouble reset button then turn the main switch back off and wait at least 10 seconds then turn it back on if the error code comes back have the fuser unit replaced
Nov 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
I have an error message: E-940. Can anyone help???
E940 - Main Switch Error
The detection mechanism is as follows:
· The machine reaches the auto-off time.
· The solenoid mounted inside the main switch turns on for 3 seconds.
· If the main switch does not turn off, the solenoid is turned off for 1
seconds.
· The solenoid is once again turned on for 3 seconds.
· If the main switch does not turn off at this point, the solenoid turns off
and E940 lights.
Possible Causes -
The main switch is defective.
The main control board is defective.
1. Turn on the main switch.
2. Enter SP5-810 (SC code reset) and press the Enter key.
3. Exit SP mode and turn the main switch off and on.
Jun 07, 2009 | Ricoh FT5832 Copier
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Canon imageRUNNER 210S Copier Logo
608 people viewed this question
old marine
old marine
Corne Viljoen
