Question about Audiovox CDM8610VM
Charging problem when I plug in the charger, the phone turns on. It should be off when charging.
  • 18 Answers
What brand of phone do u have may i ask?..because there are certain phones that do stay on while you are charging them..such as nextel.
Posted on Sep 03, 2008
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
When I plug in a charger the phone comes on. How do I charge the phone with the power off?
After the phone has turned on when you plug it in, you can turn it off. So, plug in the charger, the phone will start charging and turn on. You can then leave the charger plugged in, but just turn the phone off and leave it charging.
Sep 04, 2010 | Cell Phones
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
2 year old UTStarcom Slice cell phone not charging.
hi, this is a good indication the battery is no good but it could also mean the charger is faulty so getting the charger tested would be a good idea.
You could take your phone into a phone shop and just ask them to check if the battery will charge using one of their chargers they wont charge for this.
Let me know how you get on or if you need further assistance ok
Jan 09, 2010 | Cell Phones
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Rokr e8 won't charge
when the phone discharges completly, it can olny be charged via the charger that plugs into a wall outlet.
Aug 04, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Can't turn on my d900 with cable plugged in...
It is probably is the charging port. Have you tried a different charger?
If it is the charger port on you SGH-D900, You have 3 options.
1. get it repaired, under warranty if possible.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge
Jul 11, 2009 | Samsung SGH-D900 Cellular Phone
Audiovox CDM8610VM Logo
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
