Question about Polaroid TLA-01511C 15 in. LCD Television
My remote works but wont scroll
My t.v. works fine but I can't use the channel arrow buttons to scroll through the channels
  • 122 Answers
Did you pre program the chanels into the tv i had the same problem make sure your pointing the controller at the tv its a little **** at times
Posted on Jan 03, 2009
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Remote control
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
Aug 22, 2008 | Initial HDTV-322 32 in. LCD Television
VIzio channels won't change
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Black box in middle of screen
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Sep 15, 2007 | Toshiba 36A60 36" TV
Polaroid TLA-01511C 15 in. LCD Television Logo
169 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
