Question about Denon Audio Players & Recorders
Blows fuses every time powers on - Denon Audio Players & Recorders
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Make sure that power and ground aren't accidentally reversed. Double check all connections at the vehicle harness with a test light or preferably a voltmeter. Also, make sure that you are not overloading the power lead. There should be only 10 - 15 amps on a radio circuit. No amps or other adapter/power supplies should be connected to the radio's power leads unless they have a low current draw. Hope this info helps.
Posted on Sep 03, 2008
2003 Hyundai Tiburan Power windows aren't working. Replaced the fuse and it blew out immediately! Any ideas what to check/try? TIA
Any time a fuse blows it is because something else has a problem, it is just there to protect the other components of the electrical circuit. Since it is the power windows I would look at the power window motor. If you remove the door panels and access the power window motors you can disconnect the motors and them replace the fuse. If the fuse doesn't blow then the problem is one or both power window motors. If the fuse still blows then you have a wire that is grounded (bare wire touching metal) causing a short circuit and blowing the fuse.
Jun 06, 2015 | 2003 Hyundai Tiburon
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
a weak battery will cause the 15 amp system fuse to blow, even though the battery can still actually start the generator.
Nov 29, 2013 | Generac Electrical Supplies
Power windows
With a new fuse try putting rear windows down one at a time, Than front one at a time if the fuse only blows with one window. The window that blows the fuse has a bad motor if it blows with any window it is a switch or wireing problem. If this was helpful please leave good feed back
Apr 27, 2013 | 2002 Ford Taurus
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
I have a 25 wat fuse in my power wire connected to my amp and i keep blowing it. should i put a bigger fuse in it?
Hello grabert205,
You do not say if the fuse blows immediately upon powering up or while the amplifier is operating. If it blows immediately, I'd check the power and ground.
If it is blowing the fuse while operating, I'd try a 30A and see if it holds. At maximum output of 100 watts times 4, the amplifier needs about 31 amps of current at 12.8V. So driving it hard could certainly blow a 25A fuse.
Hope this helps.
Jun 13, 2009 | DHD LCD-9444 Car Audio Amplifier
Blowing fuses
Are you sure you don't have the positive and negative power wires reversed?
Does the fuse blow without remote voltage applied?
Nov 09, 2008 | Jensen JPA285 Car Audio Amplifier
Blowing fuses in power supply
One thing to check, would be the filter capacitator that is on the front circuit board. They are known to become shorted. The cap is fairly large, and may be mounted on the side of the circuit board that faces the front panel. Clip one lead, and apply power. If the fuse does not blow, then that is it. A second possible component, is the polarity protection diode, that is near the power jack, next to the fuse. If it is shorted, then the fuse will blow every time.
Aug 21, 2008 | Optics
1995 jeep cherokee
You have a large wire that powers the ECM, it has rubbed through and is grounding out and blowing the fuse, locate the power source for the fuse under the hood, then look for damaged wiring, check places were the wires touches the body, it will not be easy, it takes time and a keen eye.
Aug 08, 2008 | 1995 Jeep Cherokee
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
113 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
