Question about TruTech PLV16190 Television
Wrong Disc Any disc, be it CD, DVD or otherwise, does not play and comes up with the error "Reads Wrong Disc". I was wondering if there is any solution to this issue. I would love to get it resolved as soon as possible. Thank you in advance for your help.
  • hgvic3 Sep 13, 2008
    We, too have had the exact same problem with the tv's. We actually bought 2 of them, and both say "wrong disc" when trying to play a dvd. Target would not return or exchange. HELP!!
    Scholar:
  • 73 Answers
Http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Posted on Jan 09, 2009
My Magnavox DVD reads disc error
QUICK ANSWER
A disc error may be due to having the wrong type of DVD in the player, having a dirty disc in the player or the disc having scratches or cracks. When it comes to the type of disc, it must be compatible with the DVD player for it to work.
FULL ANSWER
When this error occurs, pull the disc out of the player and look at the underside for smudges and fingerprints. If these are present, using a soft cloth to gently remove them generally solves the problem. Cracks and scratches generally require replacing the disc because they prevent it from working.
or try this link..if a popup comes up on the link just close it down.
Step by Step Guide to DVD CD or Game Disc Repair The DIY Video Editor
Dec 17, 2016 | Magnavox Televison & Video
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
My cd writer is not working can nort burn the disk what should i do i have a dell d800
Your cdrom drive can read a data disc or play cd audio? Check if its CDR/CDRW not DVDR/DVDRW, buy a disk cleaner and play it on your cd/dvd drive. After that try to burn again.
Nov 12, 2010 | Dell Computers & Internet
Load dvd disc, dvd reads disc then comes up with
I am just wondering whether the unit has got condensation inside.
Just try to do this as a process of elimination.
Take the dvd and place in a warm room.Plug it into the mains (try and eject disc if not leave in) and leave for 2-3 hrs
Give it another try..fingers crossed.
Dec 04, 2009 | Panasonic DMRES15 DVD Recorder
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Dvd player combo
uncompatable disk?if not try cleaning the lens of the player by using a cd/dvd lens cleaner...the cd thing with the two brushes stuck onto it...with some cleaning fluid
Apr 25, 2008 | JVC DR-MV1S DVD Recorder/VCR
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Won't Read blank disc!!
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
TruTech PLV16190 Television Logo
48 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
