Question about Canon PowerShot A520 Digital Camera
Camera help our camera is taking pics but the screen is black and when you look at the pics on the memory card they come out the same way
  • 1 more comment
  • Anonymous Sep 09, 2008
    My A520 powers up alright, but when a picture is taken, there is no image in the viewfinder. The flash goes off but no picture shows in the viewfinder.
  • Anonymous Sep 12, 2008
    My viewfinder is a blank, black screen and no image appears, although the flash does work. All the menu icons are displayed but the screen remains black and will not show the subject image. Even when using the manual viewfinder, nothing is recorded on the memory card.
  • talks2much Sep 13, 2008
    I am also having the same problem with the Powershot A620 with 7.1 mega pixels. Black screen, shows the menu and icons on the screen but no picture registers on the screen or on the memory card.
  • 10,594 Answers
Please mention exact model number of canon camera.
Posted on Sep 05, 2008
  • Shahid Electronics
    Shahid Electronics Sep 14, 2008
    Its problem with CCD Imager in camera and you should contact nearest Canon service center to replace defective part in camera.
    Canon has free of cost repair scheme for few models. Please click on Canon CCD Issue to see details but A520 model isn't in list.
    Good luck.
Protected memory card comes on screen unable to take pics
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 21, 2014 | Fujifilm FinePix S4400 Digital Camera,...
Memory card
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
I can view the pics i take clearly but when i switch modes to take a pic the screen is black and i hear a clicking sound.. olympusfe-220
I beleive your Memory Card is the problem. Take it out and leave it out when turning it on and see what it does. Mine was doing the same thing untill I did the above and it took a picture with internal memory just fine. If it works, then you need to format the memory card using your camera setup menu. When you turn the camera on with memory card installed quickly push the green play button and it should stay on for you to see the menu.
Jul 20, 2010 | Olympus FE-220 Digital Camera
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
When taking pics will not show pics in lcd screen
If no power on the camera at all:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If there is power on the camera, but the LCD is black KODAK recommends a repair. If the camera is OoW.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Dec 05, 2009 | Kodak ZD710 Digital Camera
Memory Card claims ''no image'' and LCD black and wont take pics
first reformat memory card to FAT file system with computer, then reformat it with camera. this usually is the solution
Aug 10, 2009 | Canon PowerShot A590 IS Digital Camera
Diagonal black line appearing in the pic bottom 1/3 of screen when this does not appear white burnt out line appears in centre of screen all this appears in the pics on the memory card mostly the black...
Try formatting the memory card in the computer then format it again in the camera and see if that clears the problem. Also try another memory card but if the problem persists it probably needs a repair.
Nov 02, 2017 | Canon Cameras
Problem with 2GB Kodak memory card
hi if you place the memory card into slot of your pc or laptop and follow the instructions on screen or take to your nearest chemist they will be able to put your pics on to a disk for you when you have saved ther pics to either your pc or disk you can then delete the pics
Jan 09, 2009 | Kodak Easyshare M753 Digital Camera
Exilm EX-Z60 black LCD screen
Do you still have the pics on the memory card? If you do take the mem card out and the "format" the internal memory of your camera and then reset it. See if that helps if not you are going to have to Call the repairs center at 800-706-2534 and then keep choosing option 1. Take mem card out. Turn on camera press menu go to setup tab go up until you see format press right arrow and highlight format press set...it will say "Busy, please wait" Once you are back to where you can take pics press menu go to setup tab go up to reset press right arrow & highlight reset press set. See if that works for you.
Nov 11, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A520 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
