Question about Jenn-Air JGR8850 Gas Kitchen Range
Jenn Aire single wall oven, model # ?
Wires in the back of the oven got exposed, and I guess were touching the metal. Some of the fiberglass got burned a little, these wires connected to the ovens heating element. They are two different sizes. I'm trying to figure out what these wires are called so that I can order and replace them. The longest wire connects to a black plastic connector with holes (other wires connect to this part also)
Doubt if wares are available as a spare. just go buy some heatproof wire of the right size - should be available from any electrical shop
Posted on Sep 03, 2008
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
Jan 09, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
How to set cook time on a jenn aire electric wall oven model # W131W
You can go to :http://www.jennair.com
and download the user guide!
Sep 06, 2008 | Jenn-Air JJW8130D Electric Single Oven
Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Jun 14, 2008 | Maytag MEW5527B Electric Single Oven
Jenn Aire double wall oven
Get a long thin flat blade screwdriver. Gently pull the probe with one hand and press on the back side of the probe connector with the screwdriver until you feel no slack in the wires. Don't pull too hard! Rotate the blade of the screwdriver until the connector lines up with the opening and puill it through. Works for installing the new one too.
Jan 08, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JGR8850 Gas Kitchen Range Logo
71 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
