Question about Olympus Stylus 400 Digital Camera
Camera does not respond
With a full charge the lens does not come out ,the screen on back lights
but I can't get it to respond . As you can tell I am digital illiterate but willing to learn.
Thanks Linda Willis
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the battery compartment to make sure that the battery is making good contact or else repair
Posted on Sep 03, 2008
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Sd10 elph green
I suggest you to once try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries. you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
Oct 11, 2008 | Canon Cameras
Nikon Coolpix S610C dropped camera turns on and lens will extend but turns off and lens retracks in a few seconds. The on/off button does not always respond.
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 14, 2011 | Nikon COOLPIX S610c Digital Camera
Stops taking pictures
I have the similar problem, I turn on the camera and after the lens comes out , red light blink all this time, and suddenly it powers down without retracting the lens back in.
The battery are fully charged AA 2400mah / 2650mah Duracell at 4.0 ma with load test. I was wondering if there is any circuitry problem.? Any experts in digital camera electronics please respond? Trick: To bring back the lens back in for safekeeping i trik this, i turn it on while it is reading the memory etc and after a sec or two i turn the knob to off, this way lens goes back inside.
I have read other brands also have their cameras lens sticking out and never going back inside.
Feb 19, 2010 | Kodak EasyShare DX4530 Digital Camera
When i turn on my cybershot, the lens extends and retracts several times, then the screen goes mostly black and a message appears telling me to turn off and back on.
Same thing happened to my camera. I have the same camera. I fixed it though. I know what I'm about to say sounds idiotic, but bare with me. If you turn the power to the camera on, and catch. or grab the lens when it has fully extended and don't let it retract. Wait until it has stopped wanting to move than the fun part happends. Atleast for my camera it felt as if something got in around the lens. so if you twist the lens you will have about a fraction of play to twist the lens back and forth. This fixed mine. Try this with yours. But don't be too rough. gentle. I mean. these camera's are expensive afterall aha =)
Dec 20, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
I bought my canon sx200 in July, I loved it..this morning I turned it on, the green light displayed, the lens opened to full capacity, then nothing else responded, no picture on screen and no button...
Try removing the additional memory card, remove the batteries for 30 seconds, replace the batteries and thn turn it back on.
If this does not work then the simple answer is return it to where you bought it from a get a replacement under warranty.
Oct 26, 2009 | Canon PowerShot SX 200 IS Digital Camera
When i turned on the camera, the lens popped out then the green light is on but it stopped responding. i remove the battery, turn it on but still it wont respond.i even charged the battery and remove the...
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Samsung Digimax S730 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Not switching on
sound like a bad back light or bad lcd. replace it and you should be fine . I fix camera's also.
Nov 28, 2007 | Casio Exilim EX-S500 Digital Camera
Olympus Stylus 400 Digital Camera Logo
145 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
