Question about Toshiba e-Studio162 Copier
Help Toshiba E-Studio 162 Copier error
Occasionally an error message pops up. The message is (error L4-01). I am not sure what it means but if I turn the copier off and than back on it seems to work for a while. Any idea on what the problem is?
Posted on Oct 01, 2008
    New Friend:
How can I reset the Toshiba estusio162 without calling for maintenance
Posted on Sep 25, 2008
Please wait message on toshiba e studio 205
Hi Leonie.
Please allow me to try to help you.
The reason why you get the - please wait message on toshiba e studio 205, could be because the HDD has become corrupt. Another for this could be a fuser error.
You can find more answers to this issue -
https://www.manualslib.com/manual/1058435/Toshiba-E-Studio165.html?page=135
http://www.copytechnet.com/forums/toshiba/87173-toshiba-e-studio-452-showing-wait-during-copying.html
http://theoryreport.com/technology/toshiba/toshiba-e-studio/fix-the-f10-error-code-on-your-toshiba-e-studio-copier.html
Attached is a tutorial that might help you gain more insight into this issue.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Toshiba Office Equipment & Supplies
System error L1-00 on Toshiba e studio162D copier how can I reset this copier?
Have you tried googling this yet, asking your IT person, or reading your manual? lol
Mar 20, 2017 | Toshiba E-Studio 162 D
HDD mount failure on Toshiba 351c copier
"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Jul 30, 2014 | Toshiba E-studio 351c Color...
Clearing maintance error on toshiba e studio 18
turn off copier, hold down 0 and 8 while turning it on, when it comes up in test mode press 252, start, o, enter and then turn machine off and on
May 28, 2014 | Toshiba e-Studio 232 Black and White...
Computer can't locate my toshiba e-studio 162
Please dont try with setup wizard , please connect the usb cable between computer and printer then turn on the copier at that time new hardware found will appear, then you have to select YES THIS TIME ONLY. you have to select the driver location
May 26, 2010 | Toshiba e-Studio162 Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Jun 02, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-studio 207
Before you turn the printer on press and hold 1 3 and * and then turn the printer on. you will hear a few beeps when the beeps stop you can release the buttons. this resets the printer.
Sep 04, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Mar 20, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-Studio162 Copier Logo
692 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
