Question about Casio Exilim Zoom EX-Z80 Digital Camera
Small box appears on screen
What is this small box that appears when i turn on camera? It appears to be like a frequency band ... I cannot figure out what its for and how to remove it from screen.
  • longmore1 Dec 29, 2008
    Same problem --smallbox screen appears on left of screen- like a freqency graph. How do I remove this??
Press the up button and it should go away!
Posted on Nov 02, 2008
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
I am trying to figure out how to set the scanner frequencies
  1. Press hold then enter then enter the channel number where you want to store a frequency. Then press "FUNC" and "PGM" and the channel number will appear.
  2. Use the number keys to enter a frequency including the decimal point you want to store.
  3. Press "E" to store the frequency into the channel.
  4. Note - If you entered an invalid frequency in step two "ERROR" will appear and it will beep three times. Enter a valid frequency.
  5. The scanner automatically rounds the entered number to the nearest valid frequency. ie an entry of 155.174 will automatically be rounded to 155.175
  6. When you enter a frequency into a channel, the scanner automatically turns on the delay function and "DLY" appears. When delay is turned on the scanner automatically pauses scanning.
Mar 19, 2011 | Uniden BC72XLT Handheld Scanner
What do i key in for 2 to power of 12??
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
Nov 17, 2009 | Casio fx-300ES Calculator
I want to know how to key in to calculate 2 to the twelveth power to get anser.
You should specify your calculator and avoid posting the same question multiple times.)
Here is the solution for FX-300ES
Hope it helps
Nov 17, 2009 | Office Equipment & Supplies
2 to the twelve power equals what
In the exemples above I used 2^12. But you can enter any base (2, 3, 5.5, 16/47, ) and any exponent ( 12, 13/48, 0.007654, even negative values).
Hope it helps
Nov 17, 2009 | Casio Office Equipment & Supplies
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Oct 01, 2009 | Uniden BC350 Base Scanner
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Jan 31, 2009 | Icom IC-R5 Handheld Scanner
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Unkown functions
Lo Hi Air UHF refer to separate bands to be monitored.
25 50 75 are the KHZ steps that can be set for searching.
Using these functions can limit what is found either during close call or during search. By switching to 25 50 or 75 in will search in those size jumps. IE in 25 155.000 155.025 155.050 155.075 etc.
Mar 04, 2008 | Uniden BC72XLT Handheld Scanner
My camera won't turn on even with new batteries
Mine's doing the same thing...need help please!!
Dec 25, 2007 | Kodak EasyShare C340 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
29 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
