Question about HP iPAQ RX3115 Pocket PC
How to convert audio in notes to wav?
There are two ways to record a note. First, one can press the record button on the side of the iPAQ or start Notes and simply hit the "record" red dot - either way produces a wav file which can be played back on the iPAQ or any other wav player. The second way is to start Notes, then click New, then click the "record" red dot. This method produces an audio object within a note. It can be copied to a desktop PC and opened with WinWord. But, I can't figure out how to get that embedded audio object saved on my PC as a wav file. I have some that were recorded this way and I sure do need to play them as wavs. Is there a procedure that will convert them?
    Master:
  • 450 Answers
This was a fun project. Here's how I did it. You'll need to download a freeware audio editor named Audacity. I did this on a Mac, but it's cross-platform, and I'm assuming the menus are the same for Windows. http://audacity.sourceforge.net/ Then. (1) Copy .pwi (Note) file to PC (2) Open Audacity (3) Get the Note audio into Audacity by: Project menu Import as raw data (4) Select all of the audio by clicking below its file name at left of the graphic of the file (5) Click on dropdown menu (arrow next to file name) Set Rate to 11025 Hz (6) Convert to WAV by: File menu Export as wav
Posted on Sep 14, 2005
How to Online Convert MP3 file to WAV (Audio) file format?
The immigration attorneys Convert your audio like music to the WAV format with this free online WAV converter. Upload your audio file and the conversion will start immediately. You can also extract the audio track of a file to WAV if you upload a video. We are constantly improving our service. Right now we support over 20 input formats to convert to WAV. For example: MP3 to WAV, WMA to WAV, OGG to WAV, FLV to WAV, WMV to WAV and more. If you have a file that we can't convert to WAV please contact us so we can add another WAV converter.
Oct 09, 2012 | Audio Players & Recorders
Tip
How to convert M4P music to MP3
The music and audiobook files you purchased from online stores are protected by DRM. But most mobile players doesn't support DRM format. However you can burn the protected music files to CD-R/RW disc to make an audio CD, then use CD ripper softwares to rip the audio cd track back to MP3, WAV, WMA etc.
There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.Following the steps , then get your job one easily.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. Go to http://www.noteburner.com to download the program. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:Documents and SettingsAdministratorMy DocumentsMy MusiciTunesiTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Oct 28, 2010 | Computers & Internet
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Ipaq 111 hard reset
Soft reset Perform a soft reset
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
How convert WAV (CELP-type)to MP3? jrstat
download audio converter program. They are free an all over the internet for download
Aug 04, 2009 | Olympus VN-4100PC Digital Voice Recorder
How to use micrphone from my laptop
What kind of software do you have?
If you have Windows: go to Start Menu / Programs / Accessories / Entertainment / Sound Recorder.
plug in your mic. turn it on. say "testing...testing..check, one, two...sockpuppets, sockpuppets"
in Sound Recorder, click on the button with the red circle. You'll be recording in .wav format.
If you want better quality sound than the default, go to File / Properties / Convert Now
here you can choose a higher sampling and bit rate. Standard CD audio is 44.100kHz, 16 bit, Stereo. Take note that the higher quality the file, the more hard drive space is occupies.
If you want to get crazy with more involved audio software, I have lots more to say.
--axoplasm
Nov 02, 2008 | Audio Players & Recorders
Hard button recording doesn't work
yes your pda button has been dammag
Jan 03, 2008 | HP iPAQ rx1950 Pocket PC
Ringtones
I found this on a website. I used to have the LG VX8500 but now I have the Sidekick 3 and didn't get the chance to try it. Maybe it works....
This is for windows users.
You will need BitPim .62, as well as a CD Ripping program called CDex, found at
http://prdownloads.sourceforge.net/c...1.exe?download
Install CDex, and open it up.
Click on the Convert menu, and click where it says "Convert compressed audio files to "Wav Files"
Then Browse and find your Mp3.
Click convert, and make note of where the new .wav is saved.
Then use Sound Recorder (standard windows program --- Start>Programs>Accessories>Entertainment>Sound Recorder --- ) to open up the .wav file, and crop the part of the song you want as a ringer.
Once the file is the size you want it, go to file and then save.
Use CDex once again to reverse the conversion -- Click Convert and then click "Convert .wav files to compressed audio files".
That's all you need to do. Then just use BitPim .62 to add the file to your phone.
Nov 28, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Ipaq voice file help
I use MP3 Voice Recorder v1.21 on my ipaq WinMobile2003. Very configurable, creates high or low quality mp3s which may be attached, moved, burned on CDs or sent on floppies even. And, it's free.
Sep 12, 2005 | Compaq iPAQ H3850 Pocket PC
Embed audio notes
Since the C-5500 has audio recording capability it is possible to record brief audio notes, which become an embedded part of the image file. Open the MODE MENU and select the CAMERA tab. Toggle right to enter the CAMERA sub-menu and toggle down until you have selected the microphone icon, using the OK/MENU button. Then toggle right, select ON and press the OK/MENU button twice. The sound recording function is now enabled. About .5 seconds after the shutter is released the 4 second recording period will begin recording. You will need to point the microphone on the front of the camera toward the sound source. You can also record and record over audio notes on photos already taken. In the PLAYBACK Mode open the MODE MENU, select the PLAY tab and then select START. Pressing the OK/MENU button will start the 4 second recording period.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
HP iPAQ RX3115 Pocket PC Logo
514 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
