Question about Haier XQBM22-C Top Load Washer
Leak Sometimes when my beloved washer is draining I end up with a small pool of water on the floor. As best as I can tell the leak originates up inside near the top. I attempted to remove the top portion by removing the screws but this does not really allow access as there are hoses and, I believe, electrical cords holding things together. I can not easily see how to disconnect them.  Thanks.
  • Concussion Apr 05, 2009
    Problem is resolved.
  • 686 Answers
Post your model number for further assistance
Posted on Apr 04, 2009
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Water collects on floor behind driver's seat
Most likely the sunroof drains are clogged. It happened to mine, the floormats and floors were soaked, especially behind the drivers side. Volvo wanted to charge me $550 to clear them out and dry out the floors. Instead I took it home, rolled down the windows, parked it in the sun and let it dry out. Then I found a mechanic who blew out the drains with compressed air for only $20. He had originally quoted me $50-100, but ended up doing it for less. He said the two back drains are clogged. You can try sticking a small flexible wire down the front two yourself, then pour water down to see if it drains properly out the bottom of the car. When I looked I didn't see the two back sunroof drains, but my mechanic said they were clogged with leaves, you might be able to clear these yourself too. I would have never guessed that it was the sunroof causing this, because you don't see the water leak around the sunroof, you only see the water backing up on the floor. Don't take it to the dealership, it's a simple job and they will rip you off.
Feb 25, 2010 | 2006 Volvo S40
My Kenmore (Mod # 665.17842400) dishwasher stopped towards the end of a rinse cycle (dishes were almost clean). A pool of water is in the bottom now and the controls don't come on anymore. I just...
You may have a small leak in drain hose. check the hose when the unit is draining, you may see the leak.
Let us know if you need further clarification.
Thanks for contacting fixya.com
Dec 03, 2009 | Kenmore Elite 45986 Front Load Washer
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking underneath but all hoses are connected
When a washer is leaking, there are several areas where the liquid could be coming from.
If it only leaks during a spin cycle, it's probably caused by a leaky drain hose
Leaks on a front-load washer can occur around the door seal. This can happen because of a build-up of dirt and soap on the seal itself preventing a proper seal from taking place. Wipe the door seal carefully making sure that the edge of the gasket is clean.
Parts of a plastic bleach dispenser can crack or break off, causing a leak intermittently during the flush process. This is because bleach is a very corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust stainless steel parts..
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
Tub leaks are usually caused by a rotted tub. If this is your problem, consider buying a new washer. Sometimes a constant imbalance can be the culprit. This imbalance can rub a hole in the tub if it consistently runs off-balance. It may be possible to repair the tub with an epoxy kit. Tub replacement isn't usually very economical.
The main tub seal can also leak. This is located where the transmission and the outer tub in the centre. If this seal goes bad, it can be very difficult to replace.
Sometimes the water-inlet valve develops a buildup of mineral deposits and rust. To check this, remove the water-inlet valve and visually inspect the surface.
There is a cool product that is designed to help prevent water damage from a leaky washer. It's called a Washer Floor Tray This tray catches water leaks and prevents floor damage from overflows. This product is a must for upstairs laundries
Sep 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Fronloader Water Problem
the water inlet solenoid valve has debris stuck inside of it, thereby not allowing complete "off" mode. best to remove it and clean the water path thoroughly. valve is found by tracing the inlet water hose.
Jun 03, 2007 | Kenmore 46462 Front Load Washer
Washer leaking
bestsy, your pump could be weeping. Sometimes they will develope a small leak and sometimes they let loose. They are easy to change, 2 clips and 2 clamps. Check out the photo, other things to check would be the hoses at the fill valve and the drain hose. Sometimes overloading will cause an oversplash. Catriver..post back.
Mar 21, 2007 | Kenmore 22422 Top Load Washer
Haier XQBM22-C Top Load Washer Logo
114 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
