Question about Compaq iPAQ H3970 Pocket PC
Numerical photos I want put numerical photos on my iPAQ. Which program I need? Where I can load it? Is it easy to load? Thanks!
    Master:
  • 450 Answers
So you can just copy a jpeg file over to the IPAQ and then click on that file and it will display it. It's best to resize your photo down to below 100KB before you copy it to the IPAQ.
Posted on Sep 14, 2005
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Will not bluetooth
"The bluetooth radio failed to turn on due to insufficient driver memory"
Rename or delete BTSDKCE30.dll and BTCORELF.dll in the windows directory of PDA
Jan 18, 2009 | HP iPAQ HX4700 Pocket PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Programs won't upload to my ipaq 111 classic ppc
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
Dec 08, 2008 | HP iPAQ 111 Classic Pocket PC
HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
If still freeze after the resets, then try to do a Hard Reset.
With this way you will restore your device at the default condition.
Take care to remove any external memory from iPAQ before to this and also have it
full charged.
The bad of this....you will loose everything stored at the internal memory of iPAQ.
The good this...your iPAQ would be alive again ;-)
To to a Hard Reset press at the same time the reset button+calendar button+today button.
Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
Photo keychain
If this is like my keychain photo viewer you need to put the keychain in USB update mode before it will work.  When you first plug it in to the USB port it will show USB Charge or USB Update. Use the arrow keys to put it in USB Update mode and then press the menu power button.
At this point you can open the software and start adding photos!
Dec 27, 2007 | Innovage LCD Touch Panel Phone
Back up battery
 recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter or insert a fully charged battery into the HP iPAQ.
Oct 07, 2007 | HP iPAQ hw6515 Pocket PC
Camera pics can't be opened in my HP PC
I would have thought that the photos would be .jpg files. What software have you got on your PC to view them ?? If you right click on the file, you can choose the program with the 'Open with' command.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Javascript
Sorry, no Java with pocket IE try this program NetFront 3.2
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Kodak EasyShare Software/Printer problems
Kodak has been making a lot of changes to that program, due to problems. If you loaded the software that came with the camera, it is very likely out of date. You need to visit the Kodak website and download the latest version of the software.
Aug 30, 2005 | Kodak EasyShare CX7430 Digital Camera
Compaq iPAQ H3970 Pocket PC Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
