8mm vcr no color on playback
You suggested cleaning heads - i did and still no color onplayback
  • mzdenice Sep 03, 2008
    yes, have tried through several different tv sets using a/v cables and the regular cable (like the kind used for cable/directv) not sure what it is called
    again have cleaned the heads - used to work but now all i get is black/white on pb - no color
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you playing this back through a tv set?
  • 2,794 Answers
It could need a head adjustment. the video head may need to adjusted to put the color back in.
Posted on Sep 03, 2008
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
My Sony 8mm CCD-TR67 plays back the tapes all noisy, grainy and with colored sparkles. I biught the head cleaner an tried that but it did not help. I took of the door and tries wet cleaning it an that did...
I had the same problem. The tape cleaning helps, but it probably is a mechanical issue. My camera had the same issue. I removed the door, when you look inside you see the tension bars have notches in them they probably came loose and need to be tightened a bit.
I would suggest you tighten one first a little and play back see if it gets better, then tighten the other a little and check again. When tightening make sure you tighten at them at 1/4 - 1/2 turns at a time.
The process is a bit tedious, but necessary as not to damage the unit.
Eventually you will see the image getting better. Then you can clean the heads once more again.
Hope this helps you out,
Jan 19, 2011 | Sony Handycam CCD-TR67 Camcorder
I will assume you have tried to clean the video head, if you have not use a wet or dry cleaning tape "dry better choice" and see if that will work, the other option is use a brand new store bought blank tape T120 and set the vcr speed at sp and let it run all the way through. If all this fails it means either the video head is bad or you need alignment done inside the vcr.
Jan 10, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR will not play back correctly.
The lines usually mean a signal loss or the unit is significantly out of alignment. This unit needs to be aligned with an alignment tape for starts. Also, the heads may be slightly clogged which will require a cleaning by a professional. Cleaning tapes will not completely clean the heads. It is possible that the head/drum motor is not locked to the correct speed as well although that usually causes a loss of color.
What speed is the tape? Try a tape recorded at a different speed and report the results here.
May 05, 2009 | Televison & Video
8mm Samsung camcorder: choppy playback
This seems like a tape playback problem. Can you look at the output of the tape in the camera directly into a monitor? And checking the tapes on another machine would also be good.
The fast movement breakup can be something in the playback circuitry of the camera. It may not show up in the viewfinder. Also yo umay try repacking the tape. Fast forward it to the end and rewind it all the way.
Oct 03, 2008 | Video Cameras
VCR jitters
Is the brake tension and alignment okay? What did you clean the drum with, fluid and stick? Did you clean the rest of the path as well - erase head, audio heads, capstan, pinch roller - etc?
Apr 26, 2008 | Televison & Video
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
