Question about Sony KP-57WS500 57" Rear Projection Television
What is the part # for the thermal fuse?
I have the same problem and have no idea how to locate the proper part. . .
Could you assist in locating or providing the part number for the thermal fuse for this model (KP-57WS500)? I can't seem to fing the proper part anywhere for this . . .
Thanks for your help with this!
  • retroflexus Sep 03, 2008
    It didn't work. COuld it be that the whole G board needs to be replaced?
  • Sony Master
  • 19,396 Answers
Fuse is located on the G board. (board part no : A-1316-566-A)
Here you can download service manual and part list.
See part list.Fuse and fuse clips are F6001 and FH6001, pn 1-576-193-11
Here you can find replacements, if you do not find your model in list call them at 1-866-925-PART (7278)
Here instead you can get parts directly from Sony.
Always unplug power one hour or more before working on your TV.
If you have not worked on TVs before call a technician.
Posted on Sep 03, 2008
Where is the thermal fuse located on a frigidarie affinty dryer model # faqg7021wl0
Good Afternoon Friend, this is Z. I am happy to assist you!
The thermal fuse on your Frigidaire dryer (FAQG7021WL0) is typically located on the outlet duct. However, I show that this model also has another thermal fuse located on the flame housing. Hope this helps!
Jun 03, 2014 | Frigidaire Dryers
Thermal fuse location
take off back panel see vent flue see fuse 2 wires to it resettable
Sep 12, 2013 | Dometic Refrigerators
How do I tell what temperature my thermal fuse was set to blow at?
Hi John! You should contact one of BISSELL's Authorized Service Centers.
Here's a quink link to assist you locating one in your area.
Feb 11, 2013 | Bissell 1425 Little Green ProHeat Handheld...
Will not start
The problem is likely a blown thermal fuse.Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Dec 18, 2010 | Whirlpool LER5636P Electric Dryer
I have a kenmore dryermofel 110.62212101 and the other day i put a load of was in and set timer closed door and pressed start button and nothing happened. i have since checked all plug connections and the...
This is a common problem caused by the thermal fuse blown. The thermal fuse is wired in series with the motor and will cause the motor not running if it blows. It is located on the blower housing at the rear of the dryer. Remove the rear panel to access the thermal fuse.
Once the rear panel is off, refer to the diagram and locate the thermal fuse on the blower housing. Disconnect the thermal fuse wires and tape them together or jump a wire between them. Insulate them properly then plug the dryer in and start the dryer.
The thermal fuse (part number 3392519) is indeed blown and needs to be replaced including the cycling thermostat, (part number 3387134) also on the blower housing if the dryer start starts and works fine with the thermal fuse bypassed. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Feel free to update us about the result and development of the troubleshooting. Let us know of you need further assistance regarding the issue with your dryer. Rate the solution if you find it helpful.
Sep 22, 2010 | Dryers
Won't heat. and i cant locate the fuse
my dryer doesn't heat up to dry the clothes. The drum is running but there is no heat - the clothes remain wet. Any ideas?
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
How many thermostats are there and where are they located?
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance:
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 9)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 8)
Thermal Fuse (Item 7)
If you need assistance on how to troubleshoot a dryer, you can refer to this link:
If you have any questions, or need further assistance, please post back and let me know. I hope you find this information helpful.
Mar 21, 2010 | Whirlpool WED5700S Electric Dryer
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Dec 31, 2008 | Dryers
Whirlpool dryer LER5636JQ0 won't turn on
The thermal fuse for your dryer is located behind the rear panel. With the rear panel removed, you can locate the thermal fuse as a small white plastic device located on the blower fan housing on the lower left-hand side (facing from the rear). A resistance reading should indicate close to a short (0 ohms). If the thermal fuse IS defective, the replacement part number is 3392519. You can find all this information at Just type in your model number and look under the "Bulkhead" heading on the next page. The thermal fuse is listed as item number 7. There's also helpful part locator diagrams to assist in troubleshooting. I hope you find this information helpful. If you need further assistance, please post back and let me know.
Jun 06, 2008 | Whirlpool LER5636P Electric Dryer
Sony KP-57WS500 57" Rear Projection Television Logo
600 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
