Question about Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit
Extending the power cable
Is there a safe way of extending the power cable for the sportster 5, so that i can run the plug to the back of my car? Is it possible to just cut it and solder new wires to it? Would that ruin anything?
Thanks.
  • 752 Answers
Provided that your soldering skills are sufficient, you should be ok. Just be sure to observe the polarity (don't switch the wires around) and use an adequate sized wire.
Posted on Sep 03, 2008
My 2001 sportster wont start was running d fine now all lights work but no spark or even a click
Hi Tracey, and the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
For a prime suspect please visit the website below:
Good luck
Harley Davidson Sportster error codes and how to access them
May 11, 2015 | 2003 Harley Davidson XL 883 R Sportster
Does a 98 sportster have a crank saft sincer if so where is it located could it cause it to get no spark
Hi Anonymous, the ignition timimg sensor is located behind the timing cover on the right side of engine. Yes if it has failed you will get no spark. Below is a list of possible demons: On twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Good luck
Jan 27, 2014 | Harley Davidson Motorcycles
2003 sportster poping with lose of power
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Nov 25, 2013 | 2000 Harley Davidson XL 1200 C Sportster...
2005 sportster rotates but no start
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Apr 21, 2013 | 2000 Harley Davidson XL 1200 C Sportster...
Rough start for HD sportster 1200 xl
Hi Anonymous, and the usual supects are:
1. Spark plugs are in bad condition, improper gap, partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged.
4. Loose wire connection at one of the battery terminals,coil, or plug between the Ignition Control Module.
5. Throttle controls not adjusted correctly.
6. Water or dirt in fuel system/tank
7. Water or dirt in carburator.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricking fuel flow.
10. Inrichner valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition not functioning properly possible faulty CKP, CTS or MAP sensor.
13. Faulty ignition coil.
14. Valves sticking.
For a possible prime suspect please visit the website below and good luck:
Apr 07, 2013 | 2000 Harley Davidson XL 1200 C Sportster...
Why do I loose a cylinder under hard acceleration on my 1200 Sportster?
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
11. Damaged carburetor or intake seals.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Feb 03, 2013 | 2003 Harley Davidson XL 1200 S Sportster...
Harley delux starter is making lik a banging sound
Hi Rich, and the usual supects are:
4. Loose wire connection at one of the battery terminals especially the negative cable at "BOTH" ends,coil, or plug between the Ignition Sensor and Control Module.
8. Intake air leak.
For a possible prime suspect please visit the website below. Good luck and have nice day.
Nov 18, 2012 | 2009 Harley Davidson XL 1200C Sportster...
Will fatboy rear wheel fit a sportster
Hi Anonymous, 4 out of 5 Harley Gods give this one a thumbs up, but just to be on the safe side contact your local dealers parts department for confirmation. Good luck
Nov 16, 2012 | Harley Davidson FXDBI Street Bob...
2002 sportster lost spark to plugs
Hi Anonymous, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
Sep 07, 2012 | 2000 Harley Davidson XL 1200 C Sportster...
Have rough running 04 883 c hard to start will not idle
Hi Indianhead, and the usual supects are:
8. Intake air leak.
Apr 10, 2012 | 2004 Harley Davidson XL 883C Sportster...
Sirius Sportster 5 Satellite Radio Receiver with Vehicle Kit Logo
150 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
